Drivetrain BSH Lower Motor Mount
Hey guys,
I installed the BSH lower motor mount (street bushing) on my MCCS and I'm finding that my MINI now behaves like a giant vibrator! It is not pleasant at all. Has anyone else installed one of these? If so, are you experiencing the same thing (vibrations increasing with RPM)?
I realize that the purpose of the motor mount upgrade is to reduce engine shifting/moving during acceleration and hard cornering, but it is just not a pleasant ride any more. If this is how it's supposed to be I'm taking it off.
(edited for spelling error)
on
i have the same bushing, and from 2500 - 2800 the car does vibrate. It is kind of annoying, but the feel you get from the unit is incredible. The swap between your stock isn't to tough, so you should be able switch it back. But I would check with BSH to make sure you didnt get the race ver.
Well, I swapped out the BSH mount on Sunday and replaced with my OEM mount. Much better. I can't quite tell whether the BSH is race or street - the concentric rings on the bushing look pretty tight, suggesting race. Regardless, the swap is simple so I'll just keep the OEM one on and swap in the BSH when I want to autox or track.
A friend of mine installed the BSH and ended up removing it due to extreme vibration. Apparently, the BSH is a waste of money and they're not as good as the NM poly inserts. Why pay extra $ for something that performs the same?
Just get the NM poly inserts. They're direct bot on to the OEM and thus provides more cushion to absorb the vibration & noise. I guarantee you will notice a huge different.
Hey guys,
I took my wife shopping yesterday and she was getting nauseous with all the vibration. I think my car hit the brown note.
![Nod](https://www.northamericanmotoring.com/forums/images/smilies/nod.gif)
I returned it to stock and sold the mount. Some day I might get the NM Engineering torque arm insert (I've heard good things about it), but it's not a priority.
Bear in mind that the BSH mount is probably the cat's meow when it comes to racing/autoX applications, but IMHO it's a bit overengineered for daily driving.
To: Emvin15
The following is what the Torque Arm Insert is used for:
Tired of engine rock causing your Mini to be unstable, torque steer and miss shifts. Get that motion under control! The R55 R56 R57 MINI Cooper and MINI Cooper S has a very soft lower motor mount. As a compromise between performance and Comfort, the OEM torque arm mount is set in rubber to reduce vibration and harmonics, however it is too pliable and sloppy for the performance minded motoring. NM Engine Torque Arm Mount Insert is made of polyurethane and reduces engine movement allowing for quicker and more direct transfer of power from the engine to the wheels.
I am very satisfied with mine (NM MINI Cooper Tuning Products)..... JD
EMVIN15 Regards to Information for lower motor mount insert
Hi The Lower Motor Mount Insert that I told you about is the NM Engineering part.
I purchased mine from Way Motor Works www.waymotorworks.com
On the website under Manufacturers open where it says NM Engineering and at the bottom of the page open result page 2. Picture of the mount is at the top in the middle of the page.
You can call them at 1-317 201-8670
or International 770 234-9965
I hope this is not to confusing.................. JD
I ordered the BSH Mini Cooper Lower Motor Mount. Get this ,its kind of funny,
my car was raising up and moving around like a old Buick under acceleration so I bought a NM insert to install. Crawled under the car last week to stuff in it. Had one already!
So ,long story ,I ordered a BSH Mount ,we'll see how that works.Hope it won't be an annoying vibrator ![tongue](https://www.northamericanmotoring.com/forums/images/smilies/tongue.gif)
![Roll](https://www.northamericanmotoring.com/forums/images/smilies/roll.gif)
![EEK!](https://www.northamericanmotoring.com/forums/images/smilies/eek.gif)
silence2-38554
11-12-2015 09:39 AM
JPMontes3
08-23-2015 01:26 AM
minipopkart
08-13-2015 05:22 AM
