- Battery died now Headlights don't function properly
- boost and a/f gauge help please!!
- How many idiots does it take to screw in a light bulb?
- Ambient temp sensor & harness...
- Wire colors - anyone have a wiring diagram?
- Rear fog Light Install
- Replacing 05+ tail lights with 02-04
- speedo needle sticking
- 05 cooper s window dip
- Installing a Escort Radar detector with SmartCord
- Rear drivers side bumper repaired-tail light non functioning
- Driving light OEM switch, whats it look like when installed?
- Help Me Identify and help with Driving Lights
- What is the typical current drain when the car is off
- Reccomendations on a good battery?!?
- Losing Charge - grounding issue or battery?
- Autel MaxiDiag eu702
- Tapping circuit:Which one is the power supply that is only activated by the ignition?
- obd
- LED Bulbs for Autometer Gauges
- Installed H11 fog bulbs instead of H7. doh! Is this fatal?
- HELP! Small fire, now OBD port not working
- Garage door remote Mod
- Xenon replacement housings
- Innovate LM-2 anybody using it?
- DRIVER SIDE LOW BEAM OUT! HELP!!
- Rear Fog Enable/Program - info needed
- quick question -- wires to clock
- Driver Window Stuck in "UP" position
- OBDII pin identification
- two questions=footwell/boot
- Car doesn't start after bad driving lamp install, need help/advice!
- please delete
- replacing the factory switch console to control hood mounted lights?
- where to find foglight xenons?
- Digital/Analog boost gauge
- Sunroof, instrument lights and heater not working. Help!
- key remote not working
- Secret Ian Cull Single Click Mode!
- Electrical issues
- Need To Find A Headlight-Activated Power Source
- Potentially serious wire harness problem... need help.
- Output voltage lead tps wire...
- Speedometer backlight always on...
- MM tapless adapter 4 oil press > temp?
- Xenon help
- center brake lamp for MC 2005 cabrio
- Calculating fuel economy
- homelink custom install
- Early 2005 R50 Halogens to OEM 02-04 Projector Xenons
- Fuse Grounding Screw, please help! 2005 MCS
- Clear Tail Lights mod.
- Any possible rear window installs for RD?
- Power Steering Fan Mod.
- Chrono Pack Oil Temp Sender Location?
- AirBag seat switch connector
- Replacing Factory AM antenna, with NMO mount?
- Egg Yolk Bulb Blew out. R53
- Interior light randomly coming on?
- Electrical Mayhem; Locks Windows and Lights
- Spark plug gaps
- Driving lights instead of fog lights
- can someone HELP ASAP?
- Install MSD coil
- Osram Nightbreaker bulbs mini review
- location and color of e break line for nav install
- Horrible AM reception
- Aftermarket radios
- How to wire up a tow trailer?
- D1S Bulbs
- Lambo MCS
- Trying to get HID projector and light..
- Adding a switch to the FIAMM air horns...
- Xenon alignment mechanism broken...
- Rear fog light wiring
- Help on Unichip installation
- Where to tap for gauge lighting under toggle switches
- Need help finding vac line for boost gauge
- Spark plug removal
- Hand brake light flicker
- Oil filter adapter plate
- AC power
- Raptor Brand 35W HID Kit for $40 ???
- LED conversion for gauges?
- My Stebel Nautilus airhorn install, stock location
- OEM driving lights - center console switch position
- Need fuse help!
- AC low pressure switch and AC wiring diagram
- Programming the key fob
- Airbag passenger seat sensor failure '05 MCS
- M7 Tuning car fog lights.
- Found this great DIY
- Brake lights always on...
- The easiest and best connector ever!
- HID lights installation
- Tricking the MRS
- Optima Red Top 34R in 2002 MCS
- ProShift Street shift light
- Xenon to Halogen headlights
- Need help in detail on hardwiring a radar detector
- Airbag problem, faultcode 06
- Help with stereo install!!!
- Amperage to the horn?
- Bulb conversion chart for the MINI Cooper S
- Function of plastic battery box?
- USB howto?
- European turn signal
- Colder plug really necessary?
- Does our Coops have keyless start?
- 05-06 Key Programmed to an 03?
- Hidden radar install
- DME Connectors how to remove
- iPhone hard-wire installation question
- New battery install?
- R50 and R53 starter
- How do you replace a Xenon bulb???
- Xenon headlight out and/or flickering
- Fiberglass Headlamp ring
- Bypassing Clockspring for Remote Mount Cruise Control Buttons
- Main engine wiring harness trouble
- 1st Gen TMAP Pressure/Voltage response
- What kind of switch for folding mirrors?
- Have Halogens and want HID/Xenon? See inside.
- Will Not Start.
- Optima Red Top 34R in 2003 MCS —*Installation Question
- Interior light question
- Headlamp issue
- PLX DM-100 Gauge experiences?
- Passenger side mirror auto down
- fog light help
- Driving lights
- Interior electrical completely OUT?!?!?
- Need help on the JOEY MOD!!!
- Mysterious ticking from the boot
- Grill light MC
- O2 sensor replacement
- HK Headunit vs Non HK
- My MINI doesn't have xenon headlights but I want them
- 48 feet (or so) of LED's off of the power inverter?
- Nav Tach/Speedo in non-Nav car
- Right headlamp, where???
- What kind of light are the Driving lights?
- Heated rear seat mod. Is it possible?
- Need help re:rear washer wiring
- Autopia driving lights?/Driving lights help!
- Taillight Retrofit Kit for pre-05 S
- Check Engine light
- Hoen "Xenon-match" subjective-blueness
- Mod Ideas?
- Radio doesnt work...
- Cornering light modification
- Laser Jammers
- DIY extend MINI key fob range
- Is the MSD coil frying my Iphone
- Convert OEM Driving Lights to Fog Lights
- Tachometer trouble
- Garmin Nuvi GPS Won't Charge?
- cruise control defect
- Voltage?
- Battery Problem
- raptor shift light install
- High Beam Garage Door Opener Issue(14v and not 12v)
- Deka ETX14
- Help with idea...
- Airbag warning light! Help!!!
- Backup Light Not Working
- Speedometer Wiring Diagram
- Anyone sell the iride still?
- Installation and mounting of Escort 9500ci radar detector
- How to replace the side marker bulbs?
- Anyone have the Wolo Bad Boy or Stebel Nautilus Air horns?
- Battery almost gone, should I replace with OEM?
- How to Change BMW "spot light" Bulb
- Getting more out of the R53 MFSW
- LED Taillight Bulbs???
- Anything new out there other than Lojack?
- Best driving lights for twisty wooded roads?
- Urgent help. Got stuck with boost gauge install
- Boost gauges
- Add a circuit
- STRI Oil Pres Gauge, signal comes from...?
- Hella Driving Lights Help!
- Speedometer signal wire?
- LED fog lamp
- Weird electrical problems...
- Can this REALLY be possible?
- Strange Alta driving lights question
- FIAMM or other Air Horns for MCS
- Prosport Gauges of St. Pete Florida ROCKS!
- Info on A/f ratio gauge installation?
- Ultralight battery
- Alarm components
- DIY Non auto HVAC light bulb replace
- DIY Fog light install (in-bumper)
- eBay projectors and HID KIT on a 04 MCS???
- New lights
- Wiring diagram for rear turn signals 06 R53
- How do I disable the headlight beam adjustment
- D2S bulb replacement
- O2 simulator How-To
- 2004 Remote Key Fob
- Speedometer light in tach
- HELP - mod gone bad, want to fix before MTTS
- Light Bar
- MSD Coils Don't Use Stock Coil Bolts?
- Wipers on '06 MCS
- Wiring to mirror control panel help
- Help Install of Electronic Pro Sport Boost Guage
- Need help with PIAA driving lights
- New Sub and Amp
- '04 MFSW Question
- AUX input question
- eBay halo headlight adjustment
- what size bulb?
- Installed Autodim Mirror on '03 MC (not pre-wired) - Need Wiring help
- Angel Eyes Running Lamps Wiring Question
- Dechromed Lights Problem
- Undercar LED's
- A Mod I Wish I Had Done 2 Years Ago...
- Need Tutorial (DIY) for Fog Lights
- Help: PIAA 540s or Hella FF200s
- D2C 8000k
- low beam height adjustment
- White side marker blinkers/turn signals.
- HELP: How to install Hella Optilux 2500s
- stop automatic door lock
- Wiring diagram needed
- GBMINI is da Man
- green-yellow...yellow-green...AARRGGHH!
- Light bar install???
- Running new Blinder M45 Extreme
- Light Bar Help!!!
- Alarm on a 2004 Cooper S
- DIY Battery Disconnect (Peace of Mind)
- Newb Xenon questions
- Modding rear fog to also act with hazard lights???
- Help finding electrical connectors...?
- boost gauge flutter
- Switch Help
- iPod issues...
- Disconnecting battery before installing?
- tach problem
- Tire Pressure Sensor issue
- Full Toggle Switch Bank
- What bulbs do I use to change halogen to white bulb?
- Alta Gauge Pod
- Hydra EMS
- Help Needed - Electrical Gremlins
- Changing temperature reading on display
