View Full Version : Navigation & Audio
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15
  1. Can your stock radio be turned on without a key?
  2. Sub woofer - jl 6w3
  3. Kappa Perfect 6.1. Is it worth it???
  4. Update of Navigation system question
  5. Need help with Mini Hands Free System
  6. MINI iPod interface playlist #6-- Used to be artists order, now song order.
  7. Weird Problem with Alpine iDA-X305
  8. Making a new mount, need to know some things about the dash
  9. Operating Factory Aftermarket Ipod cable instructions?
  10. New Maps Disc
  11. chrono pack
  12. Nav voice at max volume & can't change...
  13. Aux in & ground loop isolator
  14. OEM iPhone integration
  15. iPhone 3Gs options?
  16. Parrot Bluetooth/Satellite/IPod Issue
  17. OMG HELP ME cannot install oem ipod kit...and now radio doesnt work
  18. Installing Harman Kardon Stereo
  19. 05 H/K Head unit, just bought the MINI
  20. Where to get audio work done in DC?
  21. Boost HU Dead/Asleep?
  22. My $2.50 DIY Sirius Dock
  23. iPod integration choice for a weirdo like me
  24. Is this a DICE Silverine or Silverine Pro?
  25. GPS and Rail Traffic
  26. Stereo Volume Modulation on HK, any ways to turn it off??
  27. Front Speaker Replacement / Amp Question
  28. Gps in visor
  29. Please help: Need advice on amp and how to boost volume.
  30. Dice unit on 2/2005 model R52?
  31. Ipod Connector Cord is loose.
  32. AUX input shuts off for odd reasons
  33. MFSW Control
  34. Perspective View Not Available?
  35. Blue Tooth set up
  36. Good Portable GPS Unit for 02 Mini?
  37. Replacing Blown HK amp with MRP-F300?
  38. 06 MCS W/ Nav and HK AUX INPUT PROBLEM.. HELP!!
  39. which amp should I get???
  40. Aux input - please help!
  41. what audio system do i have
  42. New Head Unit
  43. iPod Interface with EQ Control
  44. Question after changing head unit
  45. looking for a head unit that has:
  46. How to turn off Nav display
  47. 05 HK audio - possible to have ipod adaptor + aux both???
  48. 05 Harman Kardon Aux Input Problem
  49. 2005 MCS with H/K – Blown Front Right Speaker?
  50. iPod adapter questions
  51. Newb Having some trouble
  52. Radio Boost CD - Owner's Manual
  53. Confusion Abounds
  54. Panel under steering column
  55. want to replace h/k hu
  56. 12-volt Accessorize...
  57. Battery drain since IPOD installation
  58. Removing Radio
  59. Need help wiring h/u
  60. Keeping stock HU, adding aftermarket power amp..
  61. Upgrading Firmware to V32
  62. Nav to Chrono Guages
  63. double din for 1st generation coopers?
  64. Alpine iDA-x305 in a 2006 Cooper S
  65. New member, V32 nav question
  66. Grom audio adapter
  67. Can't play CD's
  68. Sub hookup questions, how to tell what stereo I have?
  69. Wher is the Amp in the 2005 Mini Convertible
  70. Tapping off rear speakers in an 09' for sub. Install help
  71. iPod adapter doesn't work
  72. Ditching the head unit
  73. Radio Mute / HU pinouts
  74. hu change?
  75. full signal help
  76. Relocating Head Unit
  77. iPhone free resources!
  78. R56 HiFi logic front 6 inch woofers in R53
  79. Alpine Head Unit w/ H/K Install HELP!!!
  80. '05 HK system same as '07?
  81. Hidden AUX input?
  82. Radio Reception
  83. How To: Wire H/K Replacement Amp & Headunit
  84. Recommendations on a headunit?
  85. Sound deadening opinions
  86. Help with my Satellite Radio!
  87. DICE radio integration help
  88. Help with wire routing:
  89. HELP. Radio stuck on...
  90. USB stop and radio start
  91. Car Radio on / off switch
  92. Auxiliary port on h/k system
  93. Moving climate control for double din
  94. Adding OEM Navigation / Speedometer possible?
  95. Can the Harman Kardon display MP3 CD Track Names?
  96. Fitting 0gauge cable
  97. Homemade Palm Pre Charging Dock
  98. Dice Silverline iPod interface question???
  99. OEM SIRIUS sound gone... please help!
  100. Alpine in MINI
  101. Help! Need to install Nuvi 360
  102. Blocking outside sounds
  103. SIRIUS mounting and power hard wiring
  104. 2004 depth specs for stock speakers
  105. Aux in the switch bank!
  106. Where is the Harman/Kardon Amp?
  107. How powerful is the H/K system?
  108. Is it safe to clean Nav. DVDs with alcohol?
  109. HD Dice questions
  110. Cravenspeed gps mount w/ Garmin Streetpilot: Installed pictures & feedback
  111. IPHONE INTERGRATION
  112. 04 MCS Stock HU Question & Need Speaker Advise
  113. Question of Multi-Functionality (NAV, IPod, Bluetooth)
  114. Possible blown H/K speaker
  115. MINI iPOD/iPhone 3G OEM radio with H/K adaptor suggestions for 2004 MINI Cooper S
  116. Nav System Unable to Read Map Because of Heat?
  117. OEM SIRIUS antenna base?
  118. Tried to remove the lover speaker grill.
  119. Radio wiring for Dice Universal FM box???
  120. Armrest Bluetooth Comfort System w/Smartphone Prep help needed!
  121. How to: Carpet fiberglass sub enclosure
  122. Time to go Alpine - How do I DIY?
  123. Stuck "MENU" button on Nav System
  124. Anyone have experience with eas eAmp module?
  125. Simple iPod hookup option for 04 (pre update) stock headunit?
  126. Stalk Radio sound distortion! looking for help
  127. iPhone integration options (R53)
  128. Question on installing the usaspec pa12
  129. Aftermarket Front Speakers on a 2002
  130. Auxiliary Jack in a 2002 Cooper
  131. Looking for input on potential setup.
  132. Noobie Question- What Bluetooth Unit is this?
  133. 2005-2006 Head Unit
  134. iPod interface issue
  135. *Unveiled* Pioneer AVIC - U, AVIC - X and AVIC - Z Car Navigation
  136. How to charge iPod?
  137. Alpine iDA-X305 help
  138. Aux Input won't give me Aux Mode
  139. Idea for GPS mount
  140. iPod and SIRIUS and phone question
  141. Factory vs Dealer Installed Ipod Adapter
  142. [DICE] help - no text display
  143. Changing Harmon Kardon 'mode' or EQ...
  144. Nuvi through the NAV?
  145. jdillon
  146. Help with complete system replacement
  147. NUVI OEM Installation Bracket?
  148. Reverse Camera + stock navi
  149. MINI theme for BlackBerry Bold
  150. OEM iPod Interface Adaptor
  151. Navigation disc issue
  152. How to test aftermarket wiring harness?
  153. Proper Remote Lead to amp
  154. MINI Dealer iPod installation AFTER purchase?
  155. Rear 6x9 Question
  156. Underseat amp grounding question
  157. 3 piece comp set
  158. Wanted: some advice on diagnosing a HK system
  159. WTB Stock replacemnt for 04 Cooper
  160. Any Gouge On The Craven FlexPod For R53 w/Chrono?
  161. H/K + JL Audio 8w7 Sub?
  162. Anyone convert ipod jack to regualr aux?
  163. H/K amp blown, is a E46 H/K amp ok?
  164. Where is the break wire need to tap it for JVC KD-NX5000
  165. New Head Unit for 04 MCS
  166. iPod cable routing to CD Changer location
  167. Should I bother with rr. speakers in changeout?
  168. GPS Newbie needs Garmin (255w?) Advice
  169. Opinions on stereo idea
  170. Could a Kenwood 6982ie fit in the 6x9 area?
  171. New system installed
  172. Rear seat delete question
  173. Replacing Speakers and Amp in H/K Convertible
  174. 2008 MINI Cooper S Cabrio integrated Bluetooth
  175. Does this setup require an amp?
  176. Thinking about changing out my H/K H/U
  177. Selling Harman/Kardon soon...
  178. H/K Amplifier Repair?
  179. Audio upgrade questions
  180. Can Copper R50 with stock headunit plug TimeDrive MP3?
  181. My non-iPod/Nav upgrade
  182. I just got new DICE from eas and need your help :'(
  183. DICE iPod installed, now no navigation voice?
  184. Need more room for amplifier! Adding Fuel cell.
  185. Factory installed Bluetooth
  186. Blaupunkt Plug N Play Amps
  187. Speaker and amp compatibility. '07 HK into an '03 HK
  188. Nav voice input
  189. Steering wheel controls
  190. Nav and MP3 upgrades
  191. Can't get my CD out
  192. Reverting to factory
  193. My radio is possessed
  194. Help with installing SWI-X
  195. Bluetooth and iPod adapter not working
  196. Help! No output from factory stereo
  197. Activating Bluetooth in a Premium Stereo
  198. Death of a navigation system!?
  199. iO Play - Bluetooth Music Streaming
  200. Opinions on audio upgrades
  201. No Nav screen on startup
  202. Head-unit ground
  203. Amps for under the seats
  204. HELP - XM Radio - no audio
  205. Navigation voice command?
  206. Replacement OEM Nav, plug and play or ?
  207. My windows, getting pwned...
  208. Switching a 2004 head unit with a 2005
  209. 2003 integration harness? Which one for H/K?
  210. Swapping a old HU for a 2005 HU
  211. Bluetooth capability?
  212. Is my NAV going out?
  213. Can I use the BMW X5 map DVD in my GPS
  214. How to tell if I have bluetooth
  215. CD runs but head unit controls don't work...
  216. R53 aftermarket BT questions???
  217. Running speakers in parallel mode
  218. iPod Touch w/factory interface
  219. Head unit not recognizing aux input
  220. Rear speakers change - DIY
  221. Few vids of the 18s
  222. Dual Box MTX9515 in MINI?
  223. Will a JL 300/4 fit under the passenger seat?
  224. I.C.E. ???
  225. Where to hide amps or satellite radio receiver type things?
  226. 2005 Mini Convertible: CD Changer Wiring
  227. Creative Zen + aux input = no music
  228. H/K Head unit + aftermarket amp ?
  229. GROM iPod interface installed
  230. WANTED: a working H/K amplifier
  231. Vibration Damping and sound proofing under rear seat
  232. Install OEM SIRIUS with H/K?
  233. Nuvi 350 — GREAT deal
  234. Need help... iPod question...
  235. Factory aux input with an HK Drive + Play
  236. iPod question
  237. 2005 H/K HU in a 2003... no disc
  238. SIRIUS receiver?
  239. 04 R53 iPod aux
  240. AVIC hideaway unit
  241. Flat pin or round pin on hard wired interface
  242. Aftermarket Nav unit in place of stock Nav
  243. Install files on Garmin
  244. iPhone in R53 connection to H/K
  245. Best Aftermarket HU w/HK system?
  246. My new boot set up
  247. Problem re-installing stock system
  248. Fair install price?
  249. Any experience w/Parrot mki 9200 & R53
  250. R50 radio manual
