View Full Version : Drivetrain (Cooper S)
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Not So Good Vibrations
  2. Ahhhhh clutch problems
  3. need help identifying a pulley.
  4. Where to get a tune in NJ/NY area?
  5. Dinan intake fitting issues, Stock lower airbox warped???
  6. Tune Shops
  7. 300hub hp on a M45.... it's done!
  8. Need help. Best place in N.Carolina for Mini Mods.
  9. High pitche whistle after dinan intake install, is it normal?
  10. Require opinions on ACT Clutch & Flywheel on R53
  11. will the Intake Cowl Mod work with the Dinan intake?
  12. Cant Decide on Exhausts DINAN vs. Strat Milltek
  13. Installing header, cant bolt it back on.
  14. After Market Clutch Recommendations
  15. where does this piece go?
  16. How to Install CamShaft
  17. What tire to get...
  18. TVS 900
  19. Have a pulley, apparently need a tune - DC area
  20. 6-Speed Manual: Slave Cylinder Solution
  21. BBS RG-F 15 x 7 wheels
  22. Engine Noise not Barn Owl
  23. rattling somewhere in the engine????? need HELP
  24. What is the best CAI and Exhaust system to get
  25. AC Delete Options
  26. more problems FML
  27. IF YOUR CAR FEELS SLUGGISH READ THiS NOW!!
  28. 16% pulley = New rattle?
  29. MCSA Tranny Fluid Change
  30. I'm WAY late, but finally PULLEY-ed the trigger!
  31. Cylinder Head Thickness: What is?
  32. Borla Exhaust Quick question
  33. Boost Leak
  34. REplacement Dual Mass Flywheel
  35. R53 Intercooler M7 verses Alta
  36. LW Flywheel/Clutch - grinding; fan always on?
  37. Engine Change Advice
  38. Front mount intercooler
  39. CNC Mini headwork by ENDYN.
  40. Boost Leak? Clutch Slip? DSC? Snow Tires?
  41. CAI registry
  42. To Cam or Not To Cam?
  43. Comparison: Stock 05 to post mod syndrom
  44. Where's this plug go? :) Clutch job almost done...
  45. Hankook Ventus V12 Evo Tires
  46. Oil filled engine mount failures - and possible remedy
  47. HELP! radiator fan gone all wierd
  48. quick exhaust question
  49. Have you ever (EVER!?!) heard of this happening?
  50. Header and 17% Pulley Installed
  51. Where can I get a tune!?!
  52. ASAP direction of fx300 clutch disc!
  53. Alta intake installed, mini review
  54. Tuners in Florida
  55. Lighter Flywheel R53
  56. Seeking tuning flash tool in MA
  57. How to get rid of lash
  58. Is alta developing a new exhaust?
  59. Anything else I should do while I install my alta intake?
  60. "Glitter" on rear end of the MINI
  61. Test of the Mini by Arden !
  62. Modifed my Alta diverter today
  63. Automatic Transmission Limit?
  64. Putting away for the winter
  65. Alta foam filter split - which glue to use?
  66. supercharger
  67. Where put my money???
  68. Straight through exhaust?
  69. yet another RMW tuned MINI :-)
  70. MT Cooper S Does Time Attack
  71. Has your mini ever broke?
  72. New intake, oil buildup on back window?
  73. Minspeed clearing out inventory
  74. I need traction!
  75. Urethane motor mounts as a complete set?
  76. San Diego pulley install?
  77. removed precat added magnaflow cat too loud
  78. GIAC INFO
  79. Big Power Options...What happened?
  80. Help! I think my s/c just blewi
  81. Problem with Hawk HPS pads
  82. How much work to add crank pulley to s/c pulley job?
  83. Powerflex Upper Engine Support
  84. Horrible noise coming from pulley/engine
  85. Home made CAI
  86. Exhaust vs. injectors for a mild tune?
  87. JCW Intake question
  88. Alta Drop in airfilter vs CAI
  89. Alta Header
  90. First Build Gearbox (02 - 04)
  91. I need help with a tune
  92. emissions nightmare
  93. Wouldn't a 2% crank and 15% sc pulley = more than 17%?
  94. m7 intake vs alta intake
  95. Can I make exhuast tips myself?
  96. New Head Install
  97. Short Shifter Mod
  98. Thermostat M7
  99. Has anyone here personally owned both a 15 and 17% pulley?
  100. Help! Pulley swap
  101. Early Crank Pulley Out, Facelift Crank Pulley In.
  102. Supercharger issue
  103. Pool on LBs new HP
  104. Used Stock 2006 LSD to 2004 MCS | Time and Issues?
  105. Fuel Consumption
  106. Problems after installing Detroit BPV :(
  107. Project 1.8L Rotrex SC Stroker
  108. Supercharger pulley swap
  109. Over Reving MINI
  110. Brembo BBK rotor options
  111. RMW Custom Tune Party in Austin, TX, Oct 16/17
  112. B&M shifter differences
  113. WEBB HEAD and NEW to MCS
  114. OEM LSD Help Needed Please!
  115. 380 injectors, JCW Re-Flash or a Different Tune
  116. 130whp dyno results...
  117. Supercharger
  118. side exhaust
  119. 17% Supercharger Pulley - Plugs and Injectors Required?
  120. Ran into some hiccups when installing the oil cooler
  121. Question about pullies and manufacturers...
  122. New to the Mini World
  123. BOV?
  124. New head for my S
  125. Anybody ever install this crank pulley?
  126. Need MTH Cartune since computer crash
  127. Oil leak at tappet cover
  128. What happened to the RMW vs Mynes tune thread?
  129. One for the Auto-box owners
  130. The ALTA scoop request
  131. Need Help with my MCS 04!!! Don't start
  132. How to fit powersteering tank
  133. Best value clutch/flywheel
  134. Unusual injector question
  135. sc pulley install questions
  136. How do you know when the supercharger goes bad?
  137. supercharger pulley help
  138. Intakes
  139. What does yo-yo mean?
  140. Brakes need a lot of force
  141. P 0171 with RMW Header
  142. Whats the deal about forge coolers?
  143. Your top 5 mods list
  144. RMW Dyno Tuning Day - North Georgia
  145. What can i do to my stock airbox
  146. Custom head build thread
  147. How long can JCW brakes last?
  148. Putting a Mini SC into an Alfa Romeo
  149. RMW Tuning OR Hubie Tuning??
  150. Cusco LSD + CM FX300 clutch / flywheel impressions
  151. Old alta pulley vs new
  152. m62 still an option
  153. what vacuum number should i see on my boost gauge at idle at sea level?
  154. R53 2005 Steptronic manual shifter no go =(.
  155. jcw injector's duty cycle
  156. Where to spend on the rebuild
  157. RMW Billet Stroker Cranks for sale!
  158. 1.8l vs. 2.0 l
  159. Metal Dust on Boot?!?!?!
  160. More RMW cars with Kevin's Auto Care in Canada
  161. Bottom-end death rattle -- rebuild options?
  162. New RMW Power Numbers - 277hp
  163. What can go wrong?
  164. TCS System
  165. REVToaster
  166. FU pully
  167. 204.9 & 177.8 at 6600 elevation
  168. Is the intake tube from the grill necessary?
  169. Installed alta catback now theres noise.
  170. 1st mods help-pulley etc
  171. Pulley help
  172. R53 MCS ATF replacement
  173. Recommended methods of securing water/meth tank in trunk?
  174. Anyone upgraded from the stock LSD
  175. TCS system
  176. Ahh my clutch is farting!
  177. Mynes Road Tour - SF Stop (Sept 12 & 13, 2009)
  178. Prime location for sprayer nozzles.
  179. Where to have a pulley installed?
  180. Sport Tips & Resonator
  181. Got my mini today
  182. R56 Brembo JCW brakes to R50-R53?
  183. Want to stay safe, but fast
  184. Spark plug comparisons, actual spark
  185. 17% Pulley, GRS Intercooler and 7600rpm rev limiter....safe?
  186. looking for a shop in San diego
  187. yahoo!! finally
  188. Running too cold
  189. OBX De-cat header VS Janspeed De-cat header
  190. Colder Plugs really necessary in new england?
  191. Newbie with an 05 Cooper S.
  192. Need help please: P1229, P1689, P1109, P1242, P0300
  193. Forge intercooler
  194. My MINI is all grown up and headed to College.
  195. flat power spot after 16% pulley install
  196. How do I get this engine bush out?
  197. New Cam Sprocket Bolt with New Cam ?
  198. HELP!! Damaged my transmission
  199. Temptation: Considering first mod -- 15% reduction pulley
  200. no exhaust? loudness
  201. Mynes Bytronik Individual Cylinder Tuning on Stock ECU
  202. Q? Are driver and passenger side muffler brackets the same?
  203. R53 Exhaust, Head, Header Survey
  204. RMW's guess what's in the box part 2
  205. Does an 06 JCW come with a Quaife???
  206. Multi-Layer JCW R53 Brake Question
  207. RMW in July '09 Roundel
  208. intake help and anyone got a k&n intake?
  209. Centrafugal superchargers for mini?
  210. powerflex bush kit
  211. A hole into the cowl area
  212. How loud is the RMW race system?
  213. Track Tires vs. Performance Street?
  214. Tune for power...
  215. 6th Gear Swap - Lower Ratio
  216. Help! My car puked oil and I don't know why.
  217. Where does this powerflex part go?
  218. inlet temps?
  219. audrey's going into surgery. your tips and suggestions?
  220. Mynes closing up shop in AZ?
  221. New ACT clutch + flywheel = master/slave cylinder failure
  222. 1/4 mile with the Cooper S..
  223. Will a 2007 limited slip Trans/diff fit into the 2003
  224. Help with shopping list - p/n's?
  225. Alta Exhaust, 2006 MINI Cooper S write-up
  226. I Need Help...
  227. First, Cheapest Mods
  228. new Manual Trans at 63005
  229. Magnaflow Exhaust for 04 MCS
  230. Which Meth Kit for DD?
  231. Intake/strut brace conflict?
  232. CARB Exempt Cold Air Intake
  233. Alta CAI V2.0 purchase inquiry
  234. My next mod....GRS Intercooler or RMW Street Header?
  235. ALTA intake install question
  236. Individual Throttle Body Kit
  237. The intake match-up thread?
  238. Custom exhaust options
  239. Mini Mania BOOST UPGRADE PERFORMANCE KIT
  240. quick ECU swap question
  241. Installed my B&M short throw today. Thoughts...
  242. Transmission fluid
  243. Alta vs. Minspeed exhaust?
  244. Unichip Custom Tuner big numbers 33hp&32ftlbs
  245. Possible to make an 03 exhaust pop like an 05-06?
  246. exhaust w/cut connecting studs still usable?
  247. Alta Sportone polished oval tip exhaust
  248. Best way to prolong Power Steering
  249. Alta Exhaust Install ?
  250. Stronger Bypass Valve Spring?
