View Full Version : Drivetrain (Cooper S)
Pages : [1] 2 3 4 5
  1. Unichip Destoyed My ECU
  2. Oil Leak????
  3. Forge BOV questions
  4. Clutch replace @ 9.5K
  5. Water temps about 215F. Is this normal?
  6. How-To Seafoam Treatment R55/R56
  7. JCW dyno pull
  8. Mini Boost gauge work with supercharger pullys???
  9. Evotech Software Tune
  10. eBay short shifter
  11. DoS CAI Owners: Defenders of Speed wants your feedback - CAI Baffle Development
  12. Data logging
  13. Which Front Mount Intercooler should i buy
  14. nm-eng what to expect?
  15. New(er) m7 Super AGS Install?
  16. Any feedback on the Forge CAI
  17. Quicksilver exhaust
  18. I am only boosting 10 or 11lbs , overboost to 12.6 help me figure out why?
  19. why are people selling their unichips?
  20. m7 Oil Catch Can Info?
  21. Need help identifying a OBDII code
  22. Lots of Alta... Bad dyno???
  23. CEL went bye bye
  24. Where to buy: Motor Mounts & Stud Conversion
  25. Alta exhaust resonator delete?
  26. Ported & Polished Head - A Missing Link in the R56 Quest for Power/Torque
  27. Alta CAI, Turbo Inlet and Noisemaker Delete Install.
  28. R56 boost reading: REV2 vs. boost gauge
  29. R56 Cutom Tune by Mynes
  30. way motor works tuner
  31. JCW sparks
  32. Arqray exhaust. What to choose???
  33. ED Downpipe Heat shield
  34. JCW Tuning Kit for '09 Clubman/Worth it?
  35. HELP loosing boost because of?
  36. denso for R56s in denso JP site only??
  37. Carbon Fiber Boot, Bonnet, Doors, and more
  38. Limiter in first and second gear
  39. GT28rs Turbo kit. Did you guys see this?
  40. modify wastegate acuator
  41. Scangauge xGauge - Now display BOOST without MAP
  42. Riss Racing Exhaust
  43. RMW Tuning Feedback -How's your R56 MINI doing?
  44. Gearbox oil viscosity?
  45. '09 JCW DYNO results - Forge Intercooler
  46. P2187 CEL
  47. Defenders of Speed Vs DDMWorks
  48. GReddy RZ BOV on r56
  49. check out this exhaust for only $300
  50. rmw tune in stamford ct at ics
  51. JCW intake with aftermarket filter?
  52. RMW N/EAST TUNE--ROCHESTER NY
  53. My new exhaust!
  54. Need Help Find Samco Induction Hose
  55. GTSPEC STB
  56. Air / Fuel Ratio works with Scangauge xGauge
  57. Help
  58. O2 Sim / P0420 code delete
  59. P1497 CEL
  60. Eisenmann exhaust?
  61. M7 Oil Catchcan
  62. blow off valves
  63. Intercooler Performance Gains?
  64. Alta or M7?
  65. factory air box
  66. GT28 turbo kit from ati
  67. Problems with Alta boost tubes, check yours!!
  68. MiniMania exhaust OEM Tips
  69. My custom Stainless Cold Air Intake
  70. Alta Catback vs. Custom DIY
  71. Installing an LSD in the R56
  72. Forge R56 Intercooler Props
  73. noisemaker diameter? for bov
  74. RMW Custom Tune Party in Austin, TX, Oct 16/17
  75. My New Mini Cooper S 2009
  76. Mini tuning in Australia
  77. DDMWorks RIS and brake vacuum
  78. Ibiza Cupra R FMIC on the 09 207 RC !!
  79. Has anyone Tried Superchips on their R56?
  80. Milltek Turboback
  81. Alta vs Helix FMICs (For those who want to see the difference)
  82. aeroforce interceptor scan tool
  83. Riss racing?
  84. Helix short shift kit
  85. Balance shaft removal
  86. 207 RC boost cut problem..
  87. Tuning the R56
  88. Alta R56 Lightened Crank Pulley
  89. Boost
  90. first mods
  91. What about this intercooler
  92. Warranty denied because of parts
  93. Clutchmasters clutch with OEM dual-mass flywheel??
  94. RMW Dyno Tuning Day - North Georgia
  95. Downpipe or Intercooler
  96. Tap sound after CAI install
  97. Dyno Disappointment.
  98. Damage wastegate
  99. nm-eng vs other intakes(alta)(m7)and soooo on....
  100. Tire pressure sensor question?
  101. installed a dos cai
  102. Downpipe???
  103. JCW dealer package questions
  104. Next Mod(s)?
  105. riss downpipe back exhaust
  106. noisemaker ?
  107. Want to blow up your engine?
  108. Stock HP & Torque Numbers for R56
  109. Anyone heard anything about "earthing" ?
  110. lowering and wheels
  111. 2.5" Custom Magnaflow DPB Vid under load
  112. Queries of the Questionable! *wiggly fingers*
  113. MINI Toolset
  114. Jan, (RMW) enlighten me on something....
  115. Easy Performance Upgrades?
  116. DDMWorks SIS finally installed...
  117. Data Log
  118. FMIC vs. coolant temp.
  119. Ist mods help-pulley etc
  120. Alta intake / 0-100 VIDEO!
  121. Problems ordering from M7 Tuning
  122. Wastegate: More Boost?
  123. how to achieve 250 bhp goal ??
  124. JCW airbox Advice
  125. short shift kit install help
  126. How to tell how much hp you have
  127. JCW Replacement Cone Filter in DDM Race Intake ?
  128. Duell AG
  129. M7 FMIC Install Help Needed
  130. 1st mods
  131. Plasma coils worth the cost?
  132. Diesel Gear Set Swap
  133. My CUSTOM CAI
  134. Engine Cooling Fan Running after Shutdown
  135. Sport button retrofit
  136. MINI Tuners... this'd be cool...
  137. M7 AGS-R Lid
  138. SCCA Solo II - BS Exhaust
  139. RMW/Helix FMIC/RR DP Tune Track Report
  140. Hey vendors, how 'bout a way to have sport mode as default?
  141. front wiper not working
  142. ***Urgent Throttle body ALTA pipe check***
  143. Aftermarket Cluch?
  144. Exhausted
  145. Oil Pressure Reading
  146. DKR ECU Tuning
  147. M7 cold air intake or Alta cold air intake??
  148. install intercooler, no grill look
  149. reflashes coming
  150. Madness FMIC Air Diverter w/ sprayers or Aftermrkt FMIC?
  151. Riss Racing Catted DP=Code 0420
  152. Mods Done Ready for Tune
  153. MAF sensor replacement for turbo engines
  154. HELP! Car is messed up!
  155. Heat shield question
  156. K&N Typhoon CAI Kit
  157. R56 with gt28 and Unichip
  158. Can I swap ECU's with a JCW
  159. Intake Question
  160. Removing R56 S ECU
  161. Alta Intercooler
  162. RMW REMOTE TUNING FOR R56 testing next week
  163. K&N intake for cooper S
  164. Broken Alta CAI
  165. DTM Tips
  166. Is it over for my R56
  167. Is it possible for an ECU to raise the MCS power by 40 HP?!?
  168. 1st Gen JCW Air Filter same as R56 Stage 1 JCW Air Filter?
  169. Boost Controller
  170. DIY water injection system
  171. Help: Question for Kappasphere (Proper ECU Tune) Announcement
  172. HKS/Helix 13/Forge BOV
  173. JCW Stage 1 intake worth it ?
  174. Question about CEL light
  175. Factory JCW muffler install on a Cooper S JCW Stage 1
  176. AEM Dryflow filter(?) Hmmn....
  177. Installing JCW software
  178. Front disk sagging
  179. Wow... LMAO
  180. ALTA Turboback rattle! UGH
  181. Eating some humble pie...
  182. SEATTLE RMW TUNE 7/24 & 7/25
  183. Ragazzon downpipe fitted.....CEL after 500km
  184. Exhaust Depot downpipe + Alta exhaust?
  185. Riss Racing MINI Exhaust needs your feedback!
  186. Boost Tubes/Hardpipes/What?
  187. Unichip with Flux power display
  188. Has anyone punched out their muffler?
  189. Noz
  190. Alta BOV installation
  191. JCW Intake vs DDM Street and Ram AIR Scoop
  192. BACK BOX question
  193. 300 WHP Help
  194. Alta Downpipe Installation scheduled/review
  195. Couple of Alta boost gauge questions
  196. Exhaust Depot's Sound clips/videos
  197. So here I sit at Exhaust Depot.... ; )
  198. Boost Down after Cat back
  199. JCW Brake Kit Question
  200. Cold side Alta boost tube install
  201. Has anyone posted a JCW dyno graph with RMW tune?
  202. Looking for a JCW intake system
  203. Huge loss of boost linked to exhaust leak ?
  204. Duell Exhaust?
  205. RMW Tune Carlisle, PA
  206. Should I trade my 05 Dinan S1 MCS for an 06 JCW?
  207. Boost Pressure Survey
  208. Boost loss or turbo hiss?
  209. Drivetrain loss?
  210. Anyone install a Forge intercooler with JCW aero kit?
  211. Stuttering and slight hesitation
  212. Just to help out k03 hybrid pics already done!
  213. RMW R56 - R53 ROCHESTER NY TUNE 6/6/09
  214. 09 MCSa & Power Steering Fan Shield
  215. MCSa Steering Response
  216. Possible HP upgrades after the JCW engine kit?
  217. Forge BOV Reviews/Thoughts
  218. Notchi-ness of Alta and Craven SSK's
  219. Automatic Shift Knob Removal and Replacement
  220. Boost Gauge at elevation
  221. Snorting Water
  222. Alta Boost Gauge Install
  223. Carbon build up Q & A
  224. Need a BOV?
  225. Need a BOV?
  226. Alta, where are we?
  227. Oh No!
  228. My Car At Riss Racing For Product Development
  229. Home made R56 CAI system
  230. My Home-made CAI for R56 S
  231. After reading pages of crap...where are we on JCW tuning?
  232. Help Choosing Tires
  233. Boost Tubes - Silicon vs Hardpipe
  234. What to do with 3grand
  235. SNEAKY CAT REMOVAL???
  236. MINI tuning
  237. Exhaust changes and CEL issues
  238. JCW tune alone worth it?
  239. My Latest Project
  240. DDM Race and a Way Heat Shield
  241. My New Carbon Fiber Custom Intake
  242. Dual Mass Flywheel to Single Flywheel
  243. RMW Utah MONSTER Tune Event!
  244. R56 DYNO
  245. Pipes and intercoolers
  246. MINI owners in Texas looking for a tune
  247. Boost gauge recommendation
  248. OEM Downpipe Differences?
  249. Revolution MINI Works (Jan) Tune Event - Limerock, CT
  250. Limiter in 1st gear?
