- NM Springs
- Ill begin the intro (and first pics) of my Mini
- wheel and tire size
- Don't plan on changing suspension, any other things I can do to improve cornering??
- BRAND NEW H&R COILOVERS FOR 279.64 ON MAZON
- Control Arms After Lowering?
- Vibration after lowering question.
- CROSS TOP MEASUREMENT
- TSW KW Varient 1
- Help me decide on my suspension set up
- Coilovers recomendation
- Has anyone every raised their MINI?
- How are KWV1 Coilovers so Cheap at Mini-Madness?
- Anyone running KW Clubsports?
- nm springs or entry level coiovers ?
- NM eng or B&G springs?
- What are the spring rates of OEM R56?
- Stock Sport Suspension question
- Alignment After Rear Sway Bar Install?
- What do you guys think of this TSW ASAN wheel?
- How do you know if you have JCW suspensions?
- Anyone got Bilstein Shocks on their R56 yet?
- Will R53 Springs Work on an R56
- Rear Sway Bar Diameter?
- Alta 50% is back guys!
- KTS Coilovers for Minis?
- KW V1 on R56 Help
- ALTA Sport Suspension Package
- Question about H&R Street Coilovers.
- Clunk after Coilover install
- Cost estimate for removing coilovers and installing stock?
- rotating the wheels
- mini cooper s lowering springs DIY HELP!
- Questions after H&R cup kit install
- R56 MCS Rear Neg. Camber?
- $250 for a rear sway install??!?!
- Finally Lowered with Wheels
- VOLK CE30,SSR TYPE C ,BBS RE OR OZ ULTRALEGGERA ?
- eibach coilovers
- First mods
- H&R + additional shock absorbers
- Do 215/45/16 tires fit on the R56 Star wheels?
- JCW Suspension Before and After
- 245/45/17
- R56 struts interchangeable w/ r53 struts?
- Looking into getting coilovers
- R56 Front sway bar
- Will H&R sports spring make it more comfortable than stock JCW?
- Suspension "Tuning"
- Cross coilovers for Clubman
- justaCooper handling roadmap
- Best reco for keeping front wheels on ground?
- Bang for the buck?
- Should I weld in the set screws of PSRS?
- Please Read if you had vibration after lowering
- NM Sway Bar End-links
- Coilover opinions
- Installing Rear Sway Bar
- NEW: GT Tuning strutbrace for the R56.
- Will they know and will they care?
- NM Tie-bar and DDM Works Ram Air Scoop
- Best setuo to get rid of slow corner wheelspin?
- R56 Lowering Springs
- Alta vs TSW end links
- Will the JCW brace fit the Ireland fixed camber plates?
- Feedback on camber plates requested.
- NM Engineering Alpha Springs & 22mm Swaybar
- How do you adjust your adjustable camber?
- How do you remove front strut on R56?
- R56 justa... handling++
- Camber & Toe settings for R56.
- JIC/Cross install guide
- KWs vs TSW KWs
- Are Camber Plates for me?
- Help!!! Need rear sway bar help!!!
- Camber adj. w/ Cross CO
- H&R RSS Coilover photo on my Mini
- Kinda OT... but who had the BRG MINI w/ black wheels getting H&R springs....?
- Camber Plates for R56 with JCW suspension?
- Yokohama's Mama
- Replacement R56 Shocks
- My TSW Spring / X-Brace Experience
- M7 coilovers + SPC camber plates = raised suspension
- Front Control Arm Removal
- How/Where to cut Bump Stops
- H&R springs and steep inclines, will it scrape?
- read this
- How do these spring rates translate to real world driving.
- Suspension setup help - fine tuning
- KW3 3's or M-7's for coil overs
- USD and RSP coilovers for the R56
- CLUBMAN S: rear sway bar
- Hotchkis HSport rear sway bar - strange sounds
- Upgrading rear sway without sport suspension
- Coilovers for a JCW Clubman
- My car went on a diet (and picked up some better brakes!)
- HKS Hyper max III coils for R56.
- Mmm Coilovers
- NM engineering spring write-up
- NM Motorsport springs it is...
- R56 M7 Under Strut System - opinions/experience?
- anybody know where I can buy this strut bar?
- Bushings that give some - camber.
- Question on sport suspension on the factory JCW
- Precision steering amplifier from mini mania
- Installed TSW springs and Alta control arms
- kw v3's
- NM Engineering torque arm insert install/engine bushings
- Thunk noise from back! Help!
- Lowered on Mach V springs!
- Longer 14mm wheel bolts in black?
- 1st gen rear control arms on 2nd gen
- H&R wheel spacers?
- Books/references to learn about suspensions
- Bilstein HDs now available for the R56!!!
- Debating JCW or H&R Cup kit
- Alignment
- H&R install and clunk... help
- BRracing AST coilovers
- Anyone ever paint their springs?
- Anybody order the NM Engineering Springs?
- Coilover options for R55
- M7 coilovers rear creaking
- H&R coilovers, owners report please!
- KW V1 Basic more or less comfort???
- Eibach springs vs TSW springs
- Spring compressor
- Looking for some info.
- JCW Clubman sport suspension ?
- Recommendations for shop to install lowering springs on R56 MINI
- JCW sway bar vs Alta sway bar
- H&R vs. Tein handling and comfort
- New tires & wheels spoiled handling
- R56 lowered - more positive rear camber
- Unichip and M7 STB, can't fit both at same time. Help, please. Thanks.
- DIY coilover install
- How to adjust rear toe?
- Mach V springs
- Mach V springs
- Strut tower brace that works with stock camber adjustment?
- X-brace underneath car
- Lowering R56 Cooper S (factory sport suspension package option)?
- R56 TSW springs installed - creaking front end?
- Noises after TSW spring install - thoughts/advice?
- JCW brakes
- Question about preventing Mushrooming
- M7 Coilovers/carbon fiber splitter review and quick DIY notes
- m7 coilover installation help~
- H&r Wheel Spacers fitment question
- Anyone know if this fits?
- Question about Alta rear control arms (install).
- Camber Plates
- Review: TSW springs, IE fixed plates
- Alta 19mm rear antisway bar installed.
- will gen1 coilovers fit gen2?
- 18" wheels, lowered, no wheel spacers?
- Put my 22mm sway bar on today!
- Pic request - TSW Springs w/ 215/45R-17 tires
- R56 Wheel Alignment
- TSW - MINI Rear Adjustable Control Arms
- New suspension
- Hi about ASB,,,,
- Koni Yellows
- What is more effective for the first suspension upgrade
- CROSS rear cable adjuster
- Alignment Problem?
- R56 Springs Install How-To
- M7 coilovers vs. Cross coilovers vs. KW V2
- Pictures of MINI's with TSW Spings? Please?
- Installed rear control arm + sways
- JCW vs. KW V1 help me decide!!
- Just Installed 19mm Alta Swaybar
- front strut removal with Helix camber plates
- Are R50 And R56 shocks, struts interchangeable?
- suspension help!
- Anyone have these on their cars?
- anybody here knows VOGTLAND spring?
- Finally? a 20mm Rear Swaybar
- Alta 22mm Sway Bar install + pictures + impressions
- Alta 22mm Rear Sway impression
- Rear lower control arm
- The Koni web site
- Coilovers and Alignment Question
- Coilovers or springs :(
- Allen head/nut at top of strut
- Mini Madness R56 suspension bushings
- Rear sway bar 1/2 adjustments?
- IE camberplates
- Wheel upsize question...
- Stock OE springs question.
- Front Strut Brace
- 17x7 Konig feathers clear wilwood 11.75/12.2 BBK?
- Color bars?
- M7 Rear Chassis Brace
- spacers and lug bolt conversions... a few questions
- Warranty info
- Anyone install Koni adjustables with stock springs?
- Teach Me
- H&R Sport Cup Kit
- General questions about multiple mods
- Front Coilovers making Popping, Thunking sound
- 15mm spacers & M7 coilvers
- Torque Specs?
- New Madness 22mm Swaybar Installed
- Any DIY advice/info for intalling Eibach or any type of lowering springs
- Wheel alignment specs
- 06-08 Konis same P/N for 09? MCS
- M7 strut bar & weird noise
- rotated tires and causing flat tire warning
- Anyone use this strut bar
- Ireland adjustable camber plates
- Question for M7 Coilover owners
- new clubman S -- has swaybar
- Anybody using BC coilovers on an R56
- ireland engineering fixed camber kit(r56)
- CROSS installed.
- Basic Suspension Question
- Slammed/Lowered with xenon levelers
- KW V1 Coilovers for LESS than $1250???
- 215/50/17 vs 215/45/17 on R56
- R53 coilovers on R56
- M7, bc, Megan, JCW ? Need help...
- Questions...
- New GTSPEC R56 front strut brace install pics
- V-MAXX Coilovers
- JCW Suspension vs. Factory Hyper-Sport Suspension
- Install price on springs?
- M7 Strut Bar - Am I supposed to feel a difference?
- JCW Suspension vs Dinan Suspension
- I did it (M7 Coilovers)
- i need a suspension solution
- Spring Comparisons
- Rear Suspension Clunking
- MİNİ R56 TOE,CAMBER MEASUREMENT?
- M7 STB on Clubman
- new parts
- Suspension goodies arrived, but..
- H&R Springs tapping noise
- adjusting coilovers?
- CAMBER PLATES
- instructions/dificulty on installing springs?
- Autocross Questions
- Opinions on lowering springs installation?
- Thoughts/opinions on urethane lower engine bushings
- ARC from Bond MINI Japan.
- TSW X-Brace for R56
- what else needed with new M7 coilovers?
- HELP Needed
- My wishful thinking~(repeat from Gen I)
- Shaking when accelerating after installing HR springs
