- UNICHIP DESTROYED MY ECU
- R56 ALARM SIMULATOR KIT
- Sport Button Modification Comparo
- Who has H13 HID KIT Installed?
- I ditched my parking lights
- do all fuses go off during crank??
- Always-hot 12v outlet?
- How do I install the battery??
- Wire Rear Fogs / Retrofit
- Front fog lamp bulbs
- CarPC wiring
- Best mod I have added to my car
- programmable flasher/brake lights
- KP Tech window/sunroof module 2009
- I want my OEM Driving Light on WHEN..
- Odometer
- Doing the "add rear fogs into the brake light mod"
- any elect techies out there help me figure out this idea
- splicing into switchboard for driving lights
- R56 Alarm Modification
- Higher Amp Driving Lights on EOM Kit?
- Innovate Mortorsport Gauges Kit
- Replacing reading lights??
- where to get ELM 327 for pc interface
- DIY Valentine 1 above mirror mount
- Matching interior neon
- OEM Driving Light Wires
- Retrofitting Airbag deactivation switch
- need help wiring up my DEFI gauges.
- Modules
- Craven Speed Tapless Oil pressure/temp
- OEM Driving light wiring question
- Sport Button and DSC on switch
- Easy accessory control...
- Driving light Installation Problem
- Where to locate Supertones?
- delete
- fog lights or marker lights?
- Installed a Boost Guage Using Add a Circuit
- Driving Lights install
- aftermarket amp
- Lighter Socket Replacement
- Bi-xenon HID kit Problem. Anyone?
- Help!! Please :)
- HELP! hot (to the touch) fuse in fuse box???
- DRLs obtained, finally
- heelp :( weird problem!
- Inexpensive alarm
- V1 Hardwire - Cabrio
- Where are the Mini "tones" stored?
- 2009 NAV video integration
- 02 Sensor
- Type of wire to use
- Help! Airbag light on after changing wheels
- Has anyone installed these?
- Cincinnati Microwave Shifter ZR4 Installation
- Rally lights - replacement glass lens
- Quick chip question...
- Retrofit Voice Control - Possible?
- Replacement Antenna
- Noisy turn indicators R56
- Oil Temp/Press Gauge Sender Locations?
- LEDs color change on cluster?
- Auto Folding Mirror MOD Request
- Weird plug?
- Retrofiting lighting package?
- Rear fog light
- Rear Fog Light Fuse?
- Retrofit smart phone prep?
- Installed Alta boost gauge - BIG problem
- data logging tool
- Looking for a MINI Tech here on NAM
- Please help me to do this...
- NEED AIRBAG HELP!!!
- OBDC gauges but analog display ?
- Rear Fog Ohm Rating?
- Bulb Out Warning
- What would happen if the bulb-out warnings keeping on...
- R56 Retrofit OEM Bi-Xenon
- Unichip experiences - Any positive ones?
- Tapping the sport button?
- Annoying Openometer
- Radar detector/GPS hiding wires
- Missing sun roof toggle
- Removing side markers?
- Driving Lights
- Trailer wiring help needed!!!
- Clear rear fog lights
- Custom Installed Stealth Passport 9500 ci detector
- The Easiest and Best Connector Ever!
- Lights or no lights? Smoke or no smoke? Helpppp!
- Retrofit MFSW cruise + radio controls R56 R55 R57
- Need help from the electronics experts
- Boost gauge
- Low beam height adjustment '09?
- Passport 9500ci - install locations
- DSC, cruise, wipers, OBC disabled... HELP!!!
- OEM driving (auxiliary/rally) lights wiring and cu
- Go into limp mode/rev limit on purpose?
- Ready to attempt rear fog light toggle switch install
- Cigarette lighter turned into something useful
- What sensor/speaker is in the top light housing?
- Low Speed Auto Door Locks
- Auto open sunroof?
- Wiring aftermarket rear fogs into brake lights
- ECU upgrades for 2009 Clubman?
- Gauge Questions
- Aftermarket Aux Lights Wiring - Need Help!
- Hella 500 Wiring
- Replace R56 Non-HiFi (Boost) Speakers, NO AMP?
- New Boost Gauge in the R56
- KBus Tap without dissassembly
- Hardwire GPS with auto on Sport button mod using fuse 32
- Light Setup
- Front parking lights
- CANBUS and MOSTBus Interfacing for CarPC
- Lighting annoyances
- Splicing the cig lighter?
- My new Hella driving lights rock my world
- Right headlamp, where???
- ScanGauge II Antics
- R56 Aftermarket Audio Mods (Please Share!)
- Replacing R56 Driving Light Bulbs
- JCW / Mini Accessory for Temp / Electrical Gauges
- Changing seat belt noise volume?
- Vanity Mirror Lights
- iPhone 3G cradle
- Convert Stock Rally lights to turn on with Low beams
- Can you silence the GONG????
- Switched power under Bonnet
- Driving lights switching on with xenon high beams
- R56 Driving Light Bulb Type
- Quick and Dirty Garmin Nuvi Install
- Retrofitting the factory self dimming rearview mirror + Homelink
- Retrofit missing Clubman fog lamps
- Wait, radar detector fries fuse panel?
- "Mood" lighting and instrument panel dimmer
- Wiring harness from hatch ??
- EE/Electrical Gurus Help! LED Resistor Ques.
- Hi-Lo HID aftermarket install problem
- LED wiring
- W5W L.E.D. replacements
- Seat belt reminder?
- Electrical Gurus: Mood Lights & Dome Light
- Airbag warnning light.....
- Fog light HID kits?
- Anybody know of a clutch-less engine start hack/mod?
- New iPod/iPhone adapter solution ??
- Electrical Diagram site!
- Newest L.E.D. fog lamps in bright white
- Fog Lights always on
- How can I use rear fog switch for extra front driving lights?
- Slim HID from ebay on a 02MCS, <$100
- Light bulb numbers
- Fuse & Wiring Issue - Gen II R56
- Trailer lights wiring?
- Programming Using J2534 interface
- led dome light installed(blue)
- LEDayLine daytime running lights
- blaster coils
- Using add a fuse to get on/off with key
- Which fuse tp use my add a fuse with for radar
- Has anyone used an OEM "sport" style button in the blank?
- DashDyno drawing down battery when car is off
- SIRIUS PNP install questions
- Gauge Pod
- Keeping Aux light button on all the time?
- What fuse should I tap in an R56?
- PLX DM-200 happy with it?
- Connecting Amp to Battery
- ScanGauge Settings, what do you watch?
- DIY Fog light install (in-bumper)
- Pics needed for wiring through the firewall
- R56 with R50 driving light harness?
- AC/Vent Fan
- Adding a 12V plug in center armrest?
- Anyone have an oil temp guage in their R56?
- DSC+ABS+handbrake light(red) all light up at the same time
- squeaky factory gauges
- Radar detector in the antenna Base (Valentine)
- Sport Button Activation
- Need Tutorial (DIY) for Fog Lights
- Rally Lights - help!
- Resetting the Service light
- Help! In middle of V1 install, can't locate ground!
- light models
- 07 auto up windows
- Sub Woofer and Amp Install Question
- HID Conversion Kit for Fogs and/or OEM Driving Lights?
- What are these Fuses for?
- Any consensus on stubby antenna vendor?
- Alta gauges lighting problem
- No power outlet in the boot????
- Anyone Ran Laser jammer Descretely?
- Sun Roof Auto open/close
- V1 Hardwire - Need Some Help
- My new back-up camera
- Removing driver side visor/vanity mirror
- Bluetooth Pairing in the MINI?
- Question about gauges!!
- problem with ALTA Boost gauge
- My new security/dashcam/DVR set-up
- installing alarm in SF bay area
- Battery Charger During Storage
- Want to upgrade the sound systems...need some suggestions
- Does this light bar fit?
- AWESOME
- extra cigarette lighter type outlet
- How do you wire four driving lights?
- Pics of Stewart Warner Gauges/ALTA Pods installed
- Shift Light
- Need help with gauge pod lighting problem
- Turn off the rear fog light bulb out notification
- Fog Light mod?
- Fuse problem
- Water temp gauge sensor wiring question
- Has anyone created a real instruction set to install OEM driving lights
- iPhone/iPod/Sat integration
- Satellite antenna for GPS?
- Has anyone hacked the shift buttons on the automatic
- How difficult is the OEM driving lights install
- '08 R56: wiring diagrams available?
- HD Radio tuner
- Disable starter for inside car show...
- Ecu Plugs?
- Scangauge vs Auterra?
- Aftermarket speakers / subs / amp installs
- Rear View Mirror Camera
- Will this work on our R56?
- R56 Horn replacement
- Innovate OT-1
- US source for cigarette lighter connectors?
- Radar
- Pioneer AVIC N3...I Need Assitance Regarding VSS
- ScanGauge II vs. Brockway Engineering R920
- Gauges installed!
- Valentine One Direct Hidden Mirror Cord Kit
- yellow fog lights?
- LED parking lights
- undercar LED lighting - moving cigar circuit to 30 always on
- Anyone retrofit power folding side mirrors?
- Installing a CompuStar Alarm/Auto start system.
- What is the bulb used on the Hyper Sport fog light?
- switching light bulbs.
- Strobeing Brake Light?
- Factory Toggle Use For Driving Lights
- "Wireless" Back-up Camera Install (pictures)
- homelink
- Contacts in Phone-dock Armrest
- Urgent: Keep Blowing Fuse (Hardwiring Sportser 5)
