View Full Version : Suspension
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12
  1. IE Fixed Camber Plates Question
  2. What is the stock ride height?
  3. IE Fixed Camber Plates: Longevity?
  4. Wheel Spacer Question
  5. bilsteins
  6. For my suspension friends - Hydro Unit ASC
  7. M7 SRP's can take a beating
  8. speed bump rattle
  9. spacers with h&r coilovers?
  10. Trying to determine what mods my MINI has?
  11. TSW KW/Hypercoil + Onasled setup = trackday fun
  12. Coilover questions.
  13. 100,000 miles with the Webb rear Sawy bar
  14. Cross Users?
  15. Winter Swaybar settings!!
  16. COMPLETE NEW SUSPENSION
  17. Front end problems
  18. Rear Shock Bushings, Any after market?
  19. Need Local Suspension Expert Wylie, TX
  20. Can't Use Koni FSDs. What's Another Good Option?
  21. Dealer: May need new control arms with JCW suspension
  22. Replacing front sway bar bushings
  23. Need some coilover advice
  24. Lower H Brace
  25. rear suspension creaking/need serious help
  26. vibration
  27. Need to cushion my ride some
  28. Mini Madness Rear Upper Strut bushings (HELP!!)
  29. front end thunk
  30. Japanese Parts Awesomness!
  31. Camber plate rattle? Normal?
  32. TSW Springs on Stock Suspension
  33. JCW big brake kit and my 16" X-Lites
  34. brake fitment issues
  35. Alignment off on my 05 MCS...would the traction light and tire pressure light go off?
  36. strut bar? yes or no
  37. alta's psrs/ castor
  38. Budget-friendly low-noise camber plates
  39. Alignment specs, correlating neg and pos toe
  40. Tire and component wear with upgraded suspension
  41. Corner balancing in Wisconsin
  42. I'm in trouble :-) (not really)
  43. front sway bar help
  44. progressive springs + stock height
  45. Rattle from front suspension
  46. Suspension & Brake Needs
  47. Where to buy: Wedsport TC005's
  48. A non-suspension thread for my suspension friends
  49. Replacing inner toe rods with sub-frame attached
  50. In dire need of assistance
  51. Suspension mods that work
  52. Anyone or any manufacturer that sells coilovers for under 600??
  53. Engine and trans bushings- PowerFlex or Ireland?
  54. Best place to buy Koni yellows...
  55. How long should tires last?
  56. How to tell when shocks need replacement?
  57. Weitec Hicon GT Coilovers
  58. Help with Pinch Bolt
  59. Is an alignment needed after new bushings?
  60. Rear Sway Bar settings
  61. probles in need of solutions
  62. Sway bar raves
  63. Strut Mount Pin is stripped
  64. Rear end "Clunk" after installing 22mm Rear Sway Bar
  65. Tein Super Street Coilovers, any new users?
  66. h-sport rear control arms weight
  67. Any rules of thumb to follow when adjusting height & dampers?
  68. Dunlop Sport Maxx on tirerack
  69. camber correction question
  70. Suspension Overhaul
  71. Lower Engine Motor Mount
  72. Opinions on what I should do.
  73. Latest adjustable control arms, comparison?
  74. Squeeky 22mm Rspeed rear sway bar drives me insane! Maybe Energy Suspension bushings?
  75. Evening out front camber, without camber plates?
  76. Megan racing, full suspension/coilover setup?
  77. m7 strut bar and webb air intake, does it work?
  78. What size spacers?
  79. Strut Bar from Amazon.com?
  80. To Grease or Not to Grease...
  81. Need advice on camber kit?
  82. spc control arms
  83. SPC Camber Plate Issue????
  84. lowered my R52 and now i have ABS and tire presure light on
  85. coilovers on 8 inch wide wheels?
  86. Noob Coilover Question
  87. Springs?
  88. H&R Coilover Instructions anywhere?
  89. 2004 MINI ONE want a coilovers, do I need additional parts?
  90. additional parts for wheel alignment?
  91. Help with Swaybar!
  92. Coilover noise
  93. PS pump how-to?
  94. R53 brake upgrade
  95. What camber plates to choose?
  96. Suspension Bushings
  97. TSW + 215/45/17 rub?
  98. Thinking BC
  99. My older Megan coilovers are killing me...
  100. Vmaxx coilovers and R56 bbk
  101. Stock 05 sports springs vs JCW springs
  102. Alta Positive Steering Response System
  103. Comments about Mini Madness strut plates
  104. Can I stiffen the suspension without lowering?
  105. Vorshlag/AST coilover install (with Pics)
  106. Cross unavailability
  107. Wilwood Brakes
  108. Been driving an 08 S automatic for a few days...
  109. Looking for ride in MINI w/ Cross Coilovers - So. Cal.
  110. coilover install cost
  111. Comparing rear strut braces... The best????
  112. Choices to make on suspension.
  113. M7 Strut Bar Install Trick!
  114. PowerFlex Gearbox Mount Clarification Needed
  115. What is the length on the OEM wheel bolts?
  116. alignment settings recommendations for autox
  117. Koni FSD replacement question
  118. H&R Sport Springs + 18in rims?
  119. JCW R53 Struts anywhere?
  120. Online parts drawings and numbers
  121. Help--Lube Swaybar Bushings now...
  122. Toe In and Toe Out numbers
  123. Ripped front strut mount!!!! HELP!!!
  124. Control arm bushings w/o BMW tool?
  125. Steering Drift after Adjustable Camber Plate Install...HELP!
  126. A Power Flex bushing note...
  127. M7 spring info
  128. Tie rods replacement options?
  129. Madness lower stress bar
  130. Sport Suspension R50 vs Sport Suspension Plus from a 2003 R53
  131. JCW Suspension = H&R Suspension
  132. Best, in ride, handling?
  133. Silly RSB question...
  134. Top nut... (Resolved)
  135. Bedding JCWs?
  136. Hard braking and steering judder
  137. Rear end loose under hard braking
  138. Cooper Sport Suspension rear sway vs. Cooper S rear sway
  139. Adjustable camber plate with pillow ball for stock type shocks
  140. H&R springs fit on OEM struts?
  141. Strut bar fit vs mushrooming
  142. Sway bar recommendation needed
  143. Need some advice before purchasing lowering springs
  144. Squeeky sway bar
  145. Help PLease>>after spring intall...help
  146. Centering wheel spacers?
  147. DOHHH!
  148. LCA bushings without tool
  149. JCW springs - where to get them from?
  150. 215/35-18 vs. 205/40-18
  151. Alignment questions
  152. What adjustable shocks are available?
  153. BRracing ast coilovers
  154. Dinan strut top relocation plates
  155. Proflex bushings, who has them in stock?
  156. GT Tech lower mid chassis brace
  157. Difference in Coilovers by model?
  158. How much damage have I done, Warranty Coverage
  159. VMaxx question
  160. Megan Racing Coilovers
  161. V-Maxx + S-Lites = No Low???
  162. Peanut butter in the shocks!?
  163. JCW steering angle stop install help
  164. PSS9 rear rattle (just installed)
  165. Why is my caster so far off?
  166. H&R TRAK + Wheel Spacers?
  167. H & R coilover Comfort?
  168. What suspension components are avaliable?
  169. Post up your track setups
  170. Show me your Tein S Techs with 17" wheels?
  171. Bavarian Autosport camber plates
  172. Upper and lower rear control arms same?
  173. H&R vs. Tein handling and comfort
  174. Aftermarket FT swaybar endlink broke
  175. H&R vs. H-Sport (Hotchkis) quality?
  176. Will my wheels fit with BBK from Wilwood
  177. After setting camber with coilovers, I bust my ball joints
  178. JCW springs and Koni FSD's?
  179. Help please - alignment specs after springs/RSB, need advice
  180. Wanted - pics of R53s w/TSW (V1 or V2) springs
  181. Koni Yellows
  182. Toe inch to degree conversion
  183. Bavarian Autosport Poly Bushings
  184. Lowering springs with stock-ish ride
  185. Bought some coilovers, have some questions
  186. SPC/Eibach camber plates and KW V1's?
  187. Source for 19mm swaybar bushings?
  188. Need new lug bolts?
  189. Soft springs, big sway bars
  190. Trying to Find Rear Quick Disassemble Strut
  191. 18" wheels, lowering, no spacers
  192. KONI suspension kit... Anyone have this ?
  193. Lowering springs...
  194. Looking For Pics of H&R
  195. New Megan Coilovers
  196. Suspension and tire advice
  197. How do you adjust rear toe?
  198. R53 Lowering Springs Chart?
  199. TSW X-Brace
  200. Uneven camber
  201. Needing Help ASAP
  202. Rear control arms and camber
  203. Koni FSD Issues
  204. Lowering springs... then need strut bar/defenders?
  205. JCW spring rates
  206. Does anyone know what it takes EXACTLY to put R56 brakes on R53?
  207. Inexpensive used H&R springs
  208. Handling effects of Rear Sway Bar vs. Camber Plates
  209. KW Suspension question...
  210. Strange steering sound after spring install
  211. H&R RSS Club Sport Coilovers
  212. pss9 settings and warranty work
  213. Wheel spacers with BC coilovers?
  214. Springs MINI service install time: 4 Hrs?
  215. OEM Control Arm Bushing Life
  216. Front strut removal
  217. PSS9 or H&R
  218. Need some springs/rim help!!!
  219. Brake Issue, JCW install
  220. TSW vs. JCW
  221. Which sway bar?
  222. Suspension HELP!
  223. leaking front strut?
  224. ? ? JCW Tower Bar and CAI Clearance ? ?
  225. Can someone explain suspension components?
  226. Brakes - all 4 corners - rotors and pads - choices?
  227. m7 STB
  228. I need help... again (sigh!)
  229. Sachs performance suspension anyone know anything
  230. Rear control arm questions
  231. Help choosing springs
  232. Difference between R53 and R56 braking systems?
  233. Helix or TSW camber plates?
  234. Coilovers... a fit and forget mod?
  235. Cooper S and JCW Suspension, Monotube or Twin?
  236. How can I stop this and fix this: Picts inside
  237. H&R sway front and rear with JCW suspension
  238. Camber plates setup
  239. Choosing my Xmas Present-Camber Plates
  240. Looking for a cheap set of swift springs
  241. cost to install camber plates
  242. Kool Vue brake pads
  243. Cross Coilover dampening adjustment
  244. Brake Cooling System(s)
  245. Mushroomed Helix camber plate / bad H&R rss coilover - need help & ideas
  246. The best way around the corner in a MINI Cooper
  247. More forgiving ride
  248. Sway Bar Bushings
  249. Snow tires...
  250. JCW GP suspension???
