- 2005 MCS - do I own a lemon?
- Overheating Problem
- Where is pass heated seat controller?
- 911 *** I am Freaking out
- dent in horn badge. can you order a new one?
- Get vehicle error code w/out OBDII tool?
- Wiring Diagram help! Anyone have a copy?
- location of airbag module?
- 100,000 mile service - Most bang for $$$?
- valve spring compressor
- e-brake
- OBD2 codes
- 'Sproing!' sound at 21km/h - R53 MCS
- Cheaper Parts
- Wing Mirror Switch
- Heavy Acceleration Causes Limp Mode
- Just replaced thermostat / housing - Rough idle?
- Problems after alternator & battery replacement
- When did 'quieter' ZF power Steering pump come out?
- Hard / Cold start issue RESOLVED!! *Vids*
- tach and dash lights dead
- map/baro circuit high input Check Engine Light
- Hatch release button fix
- CEL, chasing my tail
- Lock malfunction?
- little plastic rocker piece broke
- Reversed control on window regulator fix??? Weird.
- Hard Shifting
- Overheating- no coolant VERY LOW oil!
- Brake Squeal when wheels are turning
- Horn Problems
- Check engine light on after closing hood
- Hard to Shift, Clutch not engaging?
- Borrow airbag light reset tool?
- Fans seized up.
- Fans seized up.
- MCS coolant fan always running.
- OEM Driving Lights - Bad "Key Button"?
- power steering idle dip. r50
- Seat heater overheating?
- Roughness when braking or starting after a stop
- Aftermarket radiator support - one small difference...
- Steering wheel vibrate on my MINI?
- Steering wheel lock problem....Ideas ?
- PF16 fault after i hit a puddle
- This car is impossible to revmatch! HELP!
- SES light and dealer BS
- whistle noise?
- window problem
- Creaking/clicking sounds from drivers side front tire
- unidentified noise
- cooper vs cooper s head
- Car won't start - battery?
- Centering/Aligning the Steering Wheel
- OH MY GOD -- 2 new problems
- Got a Puncture with conventional tires
- What size is th torqx bolt on the rack
- Power Steering issues
- Problem
- Power Steering fluid volume
- Foglights mysteriously on
- overheating when car is at a sitting
- Fresh Coolant Install - Need Help
- Strange Noise & Loss of power
- New Battery, dead again!
- Help! How to replace the Core/Radiator Support!
- Rear Window Wiper Is Always On
- servicing newbie question...
- DSC/Service Engine/cylinder misfiring
- How do you open the battery?
- Car sat, now won't start, NEED HELP
- No Radio, no HVAC, and wipers going crazy
- Orange module next to Battery
- Servicing Cooper S Supercharger Oil
- Battery - how long does full charge take?
- Will 05 wheels fit on an 09 MINI!?
- exhaust smell in cabin when idling
- weird noise from Clutch on 1st gear
- ASC light Flashes
- Need a Picture or Pinout for 3-Pin CD Changer Cable
- I think i broke some thing
- How to replace tail light
- drian plug
- electrical (headlight/gauges/fan) problems
- Seafoam question
- Does my Throttle Body look right?
- Quick question about Bypass Valve Hose Clamp
- Vibration under heavy accel, especially left turns
- Wet or Dry sump?
- '06 MINI cvt transmission problems?
- faint rubbing sound
- Suspension "loose change" sound
- clutch squeel/grind into first gear
- Need advice on Power Steering Pump install
- motor mount options
- Steering Pump
- Missing 2.5 quarts of oil
- Oil residue on garage floor
- SES P0136 after 15% Pulley install
- trunk/boot is messing up, any ideas?
- Brushes for power steering pump
- Is my supercharger dying?
- Hatch Release
- Service Engine Soon Light - Misfire Cylinder 4 (R53)
- Gas strut that holds up hatch
- Bearing or CV? Ticking when turning left...
- Cam Replacment
- Is this normal?
- Oil Leak @ 50k
- Vibrating Speedometer on cold start up.
- MINI Diagonosis without Guesswork?
- Air Conditioning running hot 10-20 secs.
- Horn(s) Issue
- Transmission OR Sticky Pedal?
- mini problem
- First POST!
- Squeaky Sound
- Weird noise going uphill
- Coolant Leak near upper radiator fan hoses
- Clicking/ticking sound when on throttle
- Squeek that i just cant get rid of :(
- WTB front seats
- Shifting Problems :(
- Brake Issues - Mushy pedal after brake job. bad caliper?
- 05 MCS just about had enough
- High idle and jerky CVT Transmission
- anyone use BBA-REMAN to reman there Power Steering pump
- Vandalized steering wheel emblem
- LOUD buzzing when in drive, 03' CVT
- Antenna Snapped
- 2002 MCS A/C wont shut off, Snowflake light wont come on?
- CVT failure symptoms?
- Will an 06 seat fit on 04 tracks in the 04 ?
- Start, idle, no go
- Brake Light short?
- Airbag light and Uneven Idle
- Dealer will replace clutch but NOT flywheel, is this ok?
- Power Steering and RPM
- P1239 - 1240
- water on passenger floorboard
- Belt Squeal 2005 MCS
- Help! My car's DEAD! :(
- Door Lock Curse
- First Post-First MINI
- Front window wipers stopped working
- Power steering Pump leaking
- trunk wont open!! * HELP!!
- mechanical door lock 2003
- Lower Console Gauges and Lighter failing?
- Replacing MCS 04 Belt Tensioner
- Paint Touch Up
- Third thermostat, overheating again after 2 weeks
- ebay vendor - supercharger remanufacturer
- Interior Lights Out
- Rear Caliper Dust Boots Split
- Another Engine Noise Thread Knocking?? Sigh..(sorry)
- Clock not working.
- Engne noise when AC is on
- Ready, Fire, Aim... (2006 Cooper Auto Question)
- high rpm and service engine lamp
- Can a fried BCM cause the car to not start?
- Rolled down hill while in gear (!)
- Speedometer stuck
- Getrag 5 speed manual problems?
- Cost of New A/C Compressor
- passenger door doesn't UNLOCK **help**
- how to pull off intercooler and clean it
- help!!
- Noise while car is off in accessory
- Valve Seal Replacement? Has anyone done this?
- How do I restet sensor code for bad O2 sensor?
- Intercooler
- TSB: Change CVT ATF every 30k for longevity
- MINIUSA letter regarding failing O2 sensors in MY 04-06
- Air Conditioning help
- Dome Light? simple question.
- TSW Replacement engine mount?
- PCV valve CHANGED? When?
- 2004 MCS steering querey
- Problems keep adding up!
- Canadian parts store?
- Problem With Opening Driver's Side Door?
- Bad O2 Sensor Code
- AC Noise On Passenger Side Only W/ Fresh Air Selected
- Driver door will not unlock from interior handle
- Will this tool fit?
- i'm petrified: 03 mini cooper cvt whine
- Seat wont recline
- Heavy steering not PS Pump?
- mushroomed to point of metal failure?
- Please help! Speedo instrument cluster goes dead
- Broken headlight washer door!
- Is my power steering pump dying?
- Changing Axle Seal?
- rear right wheel getting hot
- Running Issue
- brake fluid leak
- P0326 - Knock Sensor
- 05 super charger on a 03 ?
- electric waterpump or s/c rebuild?
- Chrome Hatch Latch thing replaced with Black one?
- Squeaky door
- Could someone post pictures or diagram of air hose locations?
- Detroit Tuned Bypass Valve vs Stock Bypass Valve
- need rear window clips
- Drivers Window Leaking Issues!!!
- MCS Engine Rebuild
- Bad Gas Cap
- Windshield cracked I heard PPG is good, but where?
- Power steering pump vs. Fan
- Rebuilding the brake caliper
- Front end noise and dealer related issues
- OBD p1776 1776
- Help Please - Limp Mode starts when I run the A/C - obd = p1688
- OBDII code P1688 - limp mode when air conditioning is turned on
- ABS and Traction control light?
- Metal squeaking in gear box when getting on first gear???
- Great, now a misfire..
- CHECK THIS OUT: Crank Pulley gone bad
- replaced battery now remotes dont work
- Xenon Headlight Problem
- Driver-side Front Wheel Noise
- Driver side brake pad wearing faster than other side?
- "Hesitation" at 3000rpm/70mph
- Help! Front brake line blew and oem part not available
- Survey: Crank Pulley Failures
- Strange Engine noise
- OEM Ride Height and Hood Gap?
- Bleeding Brake & Clutch systems
- 2xx miles over warranty + Coolant leak
- Here's a weird one...
- ATTN.: ALL BBK OWNERS
- transmission question
- Vibration on driver side window
- Hesitation
- Is there a body module avaliable from someone besides Mini dealer?
- ABS DSC warning lights on
- Location of 2008 S body module
- Belt Tensioner Rattling...
- weight sensor air bag trouble
- Replacing 3rd brake light
- HELP!!!
- Transmission Fluid
- replacing power steering pump and...
- Rattling Coming from Passenger Side of Motor...
- windshield crack
- A1 Cardone PS Pump
- what is it and how do i remove it?
- PCV valve hell
- A/C blower motor
