Drivetrain SPI Twincharged MCS Race Program: Progress Report
Old 03-24-2005, 09:00 PM
Fireballed Hubie's Avatar
Fireballed Hubie
Fireballed Hubie is offline
I would like to first thank North American Motoring and the entire Mini community for all the interest and support of our Twincharger Kit and its development and for over one year now. The kit has been in production since its debut at the 2004 SEMA show and we are currently setting up authorized dealers around the country to support this product as well as new products in development.
Information from us has been few and far between and we apologize for putting the burden of education and support of our products onto our customers who have either "twincharged" their own vehicles, or have experienced rides or seen our project car at various events.
We have set up a new facility in Phoenix to become our base of operations for development of Mini related products. At this point in time, only two individuals from SPI will be directly responsible for product support and product announcements. Myself, logged in as TWINCHRGDMINI, and KC, who will be logged in as SPITech. Please feel free to direct all questions to either one of us. We will respond as quickly as possible to the best of our abilities.
Thanks again for all your interest and support as we continue to push the performance envelope.
Hubie Fuh
SPI Powerexcel
hubie@spipowerexcel.com
New Developments:
After almost eighteen months of testing, our project car has entered stage two of development. Stage one was initial development and long term testing of our Twincharger system on a completely stock engine and drivetrain. After 12,000 miles of normal and hard driving in all conditions and environments, we are confident with the performance and reliability of our components working in conjunction with the factory components. As with any other performance modifications, high performance demands higher maintanence as well as an understanding of the factory design limitations. Our system bolted to a completely stock MCS will produce anywhere from 250WHP to 265WHP depending on the vehicle and testing conditions. This has been proven over the past year in different parts of the U.S. and using the highest octane normally available in that particular region. (91-94 Octane) Our stage one kit is preset to this horsepower level because we feel this to be the reasonable reliable limitation of the stock motor. BMW has expressed to us that the components are capable of 350BHP, but they did not want to elaborate on the failure rate. One out of ten customers may be fortunate enough to have motors that can tolerate that kind of stress, but to the other nine customers, their failure rate is 100%.
There are many obstacles to making power, but the major hurdle is the piston. Overall piston design is not the issue, but it is failure due to fatigue normally associated with a cast manufacturing process. In order to reliably enter stage two, we have worked with CP Pistons to design us a stronger piston, maintaining stock specifications as to bore, compression, and wristpin location. Upgrading to forged pistons is not limited to stages, but will provide peace of mind and a solid groundwork to build upon. Given a choice of upgrading head or block, the choice is simple. The head makes horsepower, but what is horsepower without a reliable bottom end?
Currently, stage two does not exist. It exists in our race program and with the sponsors that have helped us with existing product or have developed new product that has helped us push the performance envelope. As we continue to test through racing, these products will become available, and our customers will benefit from our understanding of the products and how they integrate with factory as well as aftermarket components to make reliable power. This is only the beginning. Hopefully our efforts will motivate other manufacturers to develop products to push the envelope as well. Being enthusiasts as well, we all benefit from our combined efforts.
Manufacturers that have helped us break the 300WHP level include the following: (they are not listed in any particular order)
Design Engineering Inc.: they gave us access to their entire line of cryogenic and thermal barrier products.
MSD: upgraded ignition coil and spark plug wires. New ignition system is underdevelopment.
CP Pistons: working with us to design a strong factory replacement piston.
QuarterMaster Racing Clutches: for designing a clutch and flywheel combination to harness the power.
The rest of the formula involves a little bit of experience, some luck, and a lot of long hours and resources. Without getting into exact details, since this is still a race project, the following is a general outline of the differences between stage one and two.
Engine is still completely stock, except for the pistons.
Throttle body and supercharger are still stock.
We are using a custom SPI supercharger inlet tube and bypass that has been on the project car since the beginning of stage one testing.
We are using a custom SPI underdrive supercharger pulley in stage two.
Turbo is still T25 configuration, but one size larger in stage two.
Custom intake system, featuring 3" air horn.
SPI custom tubular manifold and 3" downpipe remains the same in both stages.
Stock ecu, ver 36 software that was original with the 2002, and piggyback APEXi S-AFC II controlling the same 440cc injectors.
Custom SPI return type fuel system with external boost dependent fuel pressure regulator and upgraded in tank pump is required for stage two.
Prototype racing clutch and lightweight flywheel is necessary to hold the power of stage two.
Upgraded MSD coil pack and wires used in stage two.
DEI cryogenic system for intake, fuel, and intercooler installed to cool everything down.
Finally, I would like to thank Alta Performance for getting to us their new top mount intercooler system for testing. Their quality is second to none and our tests showed no loss in power between our custom unit and their in stock and ready to ship upgraded unit.
We will continue to update the community with our progress and when new products are ready for release. In the meantime, let us all concentrate our energies in a positive and productive direction.
SPI Powerexcel
Old 03-24-2005, 09:05 PM
El Diablito Rojo-N20Mini's Avatar
El Diablito Rojo-N20Mini is offline
Nice use of my old trumpet for the inlet.... I was wondering how you were going to use it...
btw.... way to cave in
Old 03-24-2005, 09:21 PM
Greatbear's Avatar
Greatbear
Greatbear is offline
Moderator :: Performance Mods
Very cool photos and progress report! Looks like you have a winner. It also shows what our sometimes maligned little engine is capable of.
I'll be watching this as it unfolds.
Old 03-24-2005, 09:27 PM
MINIclo's Avatar
MINIclo
MINIclo is offline
7th Gear Gal
It DOES resemble a trumpet! What! No cowbell? LMAO!
Hubie...looks great! Thanks for the great report and pix! Good luck with it!
Clover
Old 03-24-2005, 09:29 PM
Tüls's Avatar
Tüls
Tüls is offline
Turbius Maximus
great stuff Hubie...nice write up...
call me
Old 03-24-2005, 09:31 PM
Greatbear's Avatar
Greatbear
Looks like we gotta change the phrase...
NEEDS MORE TRUMPET!!!
Old 03-24-2005, 09:33 PM
MINIclo's Avatar
MINIclo
MINIclo is offline
7th Gear Gal
I want to hear the toot of that horn! VAROOOOOM!
Clover
Old 03-24-2005, 09:42 PM
goaljnky's Avatar
goaljnky
goaljnky is offline
Hmm, shiny, arghhhhhhh!!!!!
Old 03-24-2005, 09:45 PM
xsmini's Avatar
xsmini
xsmini is offline
nice
Thanks for the update
Nik
Old 03-24-2005, 09:46 PM
Yucca Patrol's Avatar
Yucca Patrol
Yucca Patrol is offline
That mini's horn would suck you in, chew you up, and leave your remains as nothing more than a little black cloud of exhaust behind one insanely fast MINI!
Way to go SPI!
Old 03-24-2005, 09:48 PM
british kompressor's Avatar
british kompressor
british kompressor is offline
OMG!!!
it's alive!!!
Old 03-24-2005, 09:49 PM
camelpilot's Avatar
camelpilot
camelpilot is offline
That trumpet nearly had me balling.
Old 03-24-2005, 09:56 PM
Ryephile's Avatar
Ryephile
Ryephile is offline
Awesome write-up Hubie
Old 03-24-2005, 10:13 PM
tsukiji's Avatar
tsukiji
tsukiji is offline
WOW! that aint vapor
Old 03-24-2005, 10:37 PM
hafid's Avatar
hafid
hafid is offline
fantastic! hope to see it when i'm in town soon!
Old 03-25-2005, 01:35 AM
Cooper_Si's Avatar
Cooper_Si
Cooper_Si is offline
congrats on an awsome build !! especially keeping it reliable too
WELL DONE
Old 03-25-2005, 04:28 AM
uae mini's Avatar
uae mini
uae mini is offline
hmm, so when do we get a twin turbo version?
Nice setup you got there.. I'll wait for a while before I purchase any kits.
Lots of new goodies
Great job guys!!
Old 03-25-2005, 06:27 AM
dominicminicoopers's Avatar
dominicminicoopers
dominicminicoopers is offline
Hubie & KC, I can't wait to see what that beast will do on a track!
Maybe we can get you to go to one of these events at firebird :smile:
Old 03-25-2005, 07:01 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
andy@ross-tech.com is offline
Yowza! When is it's dragstrip debut? I hope to add a row for 12-second cars ASAP. :smile:
http://www.ross-tech.net/andy/mini/d...artermile.html
Old 03-25-2005, 07:12 AM
sndwave's Avatar
sndwave
sndwave is offline
Coordinator :: Gulf Coast & Panhandle MINIs
Awesome
Old 03-25-2005, 07:25 AM
erik99's Avatar
erik99
erik99 is offline
What pictures
Edit: Oops, there they are
Old 03-25-2005, 07:28 AM
05JCWS's Avatar
05JCWS
05JCWS is offline
The whole system looks photoshoped.
Old 03-25-2005, 07:56 AM
Fireballed Hubie
Thanks I take that as the ultimate compliment. For years, we have been turning our fantasies into realities. That is what drives us to push the envelope.
Old 03-25-2005, 08:31 AM
Cooper_Si's Avatar
Cooper_Si
i like to see that the engine is capable of such BHP , but what about the gearbox and running gear? is all this ok handling that sort of power hike ? :smile:
Old 03-25-2005, 08:32 AM
I would love to meet you some time... you and PC are case studies
Quick Reply: Drivetrain SPI Twincharged MCS Race Program: Progress Report
