Rust :: door sill area of '02-'05 MINIs
community service...... while chasing down some wiring issues we took the rubber strip that runs along the length of the passenger door and there it was.....rust..... the rust was about an inch long and pretty well started....we took a steelbrush and painted the bare metal with rust prevention paint so problem solved but we were both surprised......if you have an older car you might look.... my car lives in Atlanta....very little to no salt
Warranty is for perforation which means a hole.Also the Mini warranty specifies it has to have the underbody inspected by the dealerl and a yearly underbody flush.Most new car rust warrantys are like this including some large name aftermarket warrantys.The overriding common thought is that through yearly inspection they can catch a problem before it gets to a warranty claim.The only problem is the customer is paying for this during the service of vehicle.This is how I see it with most warrantys.
Originally Posted by UN4G1VN
What year is your Mini?
https://www.northamericanmotoring.co...ze=big&cat=500
Originally Posted by snoopy
It is a 02. Here is a photo, and what is a bit of a worry is that we have not had rain for weeks (live in a hot dry place) but i wash the car about 3 days ago and it was still real wet under the trim rubber. also you can see the untreated area were the rust is at its worst.
Dang! I haven't been around in a while. First thread I pull up is this one. Go outside & have a look, & sure enough, I've got rust under the seal on both sides! FWIW, the car is an 11/02 build 03.
I'm gonna sand & paint, then find some butyl or silicone & seal the area to keep water out..
Originally Posted by okraD La
Mine is an 2002 MCS 08/02 build....Pulled up the rubber seals and voila. the rust runs down the entire length of the door, check it out...Mine is a Drk Silver too..
I've got rust too....What is the best way to repair gang, help me out I'm dying over here...
Thanks for the public service announcement!
Originally Posted by chrisneal
My car is only a year old, so I doubt I have the rust yet, but I'd like to take care of this before it starts. Can someone explain what types of products to use? Are you planning on sealing the edges of the rubber strip to the metal/paint?
This might be related somehow. When I took my car in for little warranty issues, one of my complaints was the door sill trim insert (the silver MINI COOPER S) had become frosty/corroded around the edges and the plastic film had begun peeling off. the dealer replaced this and blamed it on the lower door weatherseal (not the soft rubber sealing the interior, rather the 'sweep strip' mounted under the door itself) and supposedly 'adjusted' this piece. I noticed there was less built up water in the area afterwards, but now the passenger's side sill trim is doing the same thing.
I guess I will check out what lies beneath the weatherstrip on my car when I get a chance (10/02 build).
the best stuff to address rust that I know of
http://www.por15.com/
Never restored any Mini's but used this stuff on my plymouth and dad's olds and I swear by it now.
