View Poll Results: If you had mushrooming or a cracked strut mount please vote
mushrooming: stock suspension / 15" non-runflat tires
32
3.00%
mushrooming: stock suspension / 16" runflat tires
83
7.79%
mushrooming: stock suspension / 16" non-runflat tires
68
6.38%
mushrooming: stock suspension / 17" runflat tires
346
32.46%
mushrooming: stock suspension / 17" non-runflat tires
214
20.08%
mushrooming: stock suspension / 18" runflat tires
22
2.06%
mushrooming: stock suspension / 18" non-runflat tires
24
2.25%
mushrooming: lowering springs / 15" non-runflat tires
0.28%
mushrooming: lowering springs / 16" runflat tires
0.66%
mushrooming: lowering springs / 16" non-runflat tires
16
1.50%
mushrooming: lowering springs / 17" runflat tires
31
2.91%
mushrooming: lowering springs / 17" non-runflat tires
58
5.44%
mushrooming: lowering springs / 18" runflat tires
0.38%
mushrooming: lowering springs / 18" non-runflat tires
18
1.69%
cracked strut mount: stock suspension / 15" non-runflat tires
24
2.25%
cracked strut mount: stock suspension / 16" runflat tires
3.19%
cracked strut mount: stock suspension / 16" non-runflat tires
32
3.00%
cracked strut mount: stock suspension / 17" runflat tires
112
10.51%
cracked strut mount: stock suspension / 17" non-runflat tires
74
6.94%
cracked strut mount: stock suspension / 18" runflat tires
0.56%
cracked strut mount: stock suspension / 18" non-runflat tires
14
1.31%
cracked strut mount: lowering springs / 15" non-runflat tires
0.28%
cracked strut mount: lowering springs / 16" runflat tires
0.56%
cracked strut mount: lowering springs / 16" non-runflat tires
11
1.03%
cracked strut mount: lowering springs / 17" runflat tires
11
1.03%
cracked strut mount: lowering springs / 17" non-runflat tires
25
2.35%
cracked strut mount: lowering springs / 18" runflat tires
0.47%
cracked strut mount: lowering springs / 18" non-runflat tires
0.75%
Multiple Choice Poll. Voters: 1066. You may not vote on this poll
Poll: Mushrooming/strut mount failure data collection
Old 09-08-2006, 10:35 AM
caminifan's Avatar
caminifan
caminifan is offline
I have been wondering about a few things that might cause (or contribute to) the strut tower mushrooming - lowered springs vs. 17 and 18 inch wheels (with the corresponding reduced tire sidewall). So, for those of you that have experienced non-catastrophic mushrooming and/or strut mount failure (failure that was not due to things like hitting a pothole; but occurred over time), please post what size wheel and tire (also include whether you had runflat tires) you were running during the period immediately before the mushrooming and/or strut mount failure was noticed. Also, please post whether you have the stock springs or lowering (and presumably progressive rate) springs were installed on the car.
Thanks in advance to all who post.
Summary from posted information:
17 inch wheels + runflat tires (presumably 205/45-17s) + stock suspension:.........1
Old 09-08-2006, 10:42 AM
MrV's Avatar
MrV
MrV is offline
No crack in the strut tower but had mushrooming at the last check in at the dealer.
17"
Runflats
stock suspension.
Old 09-08-2006, 10:46 AM
Mini Works's Avatar
Mini Works
Mini Works is offline
As someone who worked on many cars with that issue,
I can tell you from our experience, that it does not matter what size wheel or what springs you are running.
It seems that the problem is due to a combination of things,
1) the factory suspension is way too stiff, and the factory shocks do not absorb the bumps like they are supposed to.
2) There is a problem with the design and the construction of the shock towers themselves.
So here are our suggestions, to prevent this from happening,
1) Change to a better quality shock (I am not going to name any)
2) Install a strut tower bar or reinforcement plates.
Hope this will help
Victor
Old 09-08-2006, 10:53 AM
dave's Avatar
dave
dave is offline
pug poo picker-upper
I just added a poll to this thread to make the data collection easier. There are some additional options in the poll.
If you had both mushrooming and strut mount cracking you may vote for two different options so you can record your configuration for both issues.
caminifan's Avatar
caminifan
2) Install a sway bar or a tower reinforcement plate.
Hope this will help
Victor
A third suggested modification may be to go to a combination of 16 or 15 inch wheel with non-runflat tires. Lets see what the data show.
Old 09-08-2006, 10:56 AM
caminifan's Avatar
caminifan
Thank you! A poll summary is much more efficient than my manual efforts at summarizing the poster's input.
The poll feature is an absolute trip! So far, it seems that the ticket to avoiding the mushrooming and/or strut mount failure is to go with 16 or 15 inch wheels and non-runflat tires and the stock suspension.... Wonder if that trend will hold....
Old 09-08-2006, 11:26 AM
heyduard's Avatar
heyduard
heyduard is offline
Heh. There should be an option for poor quality roads as well.
Old 09-08-2006, 02:27 PM
GoodFinder's Avatar
GoodFinder
GoodFinder is offline
Interesting Comparisons
My '05 MCS with 25,000 miles on it - everything is perfect.
My new GP with 2,500 miles on it - slight upward crease (about 2.5 inches long) in top of driver side strut tower (passenger side perfect).
Go figure. The only thing that comes to mind is that hidden expansion joint in Route 66 during one of the MTTS legs ... "bam" that was a doozy!
Old 09-08-2006, 02:28 PM
meb's Avatar
meb
meb is offline
Hope this will help
Victor
Why do you think adding a awaybar will help prevent strut tower mushrooming?
The idea here is excellent, but you realize that it is somewhat faulted? Probability will be affected by the number of miles driven, type of road, and, the number of respondents as a ratio to the actual number of cars on the road and voter participation. but then, the poll would take three years to complete.
Old 09-08-2006, 02:41 PM
Mini Works's Avatar
Mini Works
I was just checking if you guys were paying attention
We meant Strut tower bar,......NO sway bar
Sorry for the typo
Victor
Old 09-08-2006, 04:10 PM
caminifan's Avatar
caminifan
I don't think the objective is to get to 95% confidence (at least that wasn't my objective). Rather, a general trend of things to consider as likely contributing factors was my objective. At this preliminary stage, it does seem that with things like 17 inch or higher wheels, runflat tires and lowering springs on the car, you have higher chance of mushrooming and/or strut mount cracking/tearing.
Again, thank you to everyone who participated in the poll.
Old 09-08-2006, 04:12 PM
caminifan's Avatar
caminifan
How is your '05 MCS equipped? And, I hope you participated in the survey.
Old 09-08-2006, 04:52 PM
GoodFinder's Avatar
GoodFinder
My '05 MCS
Yes, I participated in the survey. Here is a link to another thread with full description on how my '05 MCS is equipped:
https://www.northamericanmotoring.co...ad.php?t=78117
Old 09-08-2006, 05:20 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Bilbo-Baggins is offline
`02 MCS with 16" wheels for the summer and 15" wheels for the winter (pothole season) 37,000 smiles. No mushrooming or cracks.
`06 MCS with 16" wheels for the summer and 15" wheels for the winter (pothole season) 9,700 smiles. No mushrooming, no cracks.
Old 09-08-2006, 05:52 PM
gizzer777's Avatar
gizzer777
gizzer777 is offline
That was one reason I put in a strut brace too
I had hoped the strut brace would help with the mushrooming Towers syndrome...we shall see...mean time it has changed the cornering of the MCS...for the better...for the better! I used the JCW only because I got a great deal on it!
Sorry for the typo
Victor
Old 09-08-2006, 06:06 PM
Fatherdeth's Avatar
Fatherdeth
Fatherdeth is offline
My base model Cooper never had mushrooming happen, and the funny thing is, I had 16" wheels with lowering springs. To add to that, I had 45 series tires. I was so sure that I would get a cracked mount/mushroomed strut tower with this combo being that there wasn't a lot of rebound. Now I go and trade the base model in on a Cooper S, and it has mushroomed strut towers. The S has 17" tires with runflats and stock suspension.
Old 09-08-2006, 08:37 PM
The MINITOR's Avatar
The MINITOR
The MINITOR is offline
Hey I'm off the chart!
mushrooming and cracked strut mount: lowering springs and aftermarket shocks / 19" non-runflat tires and strut tower bar.
The mushrooming if very minor so maybe the strut tower bar helped prevent it from being bad, or maybe it did nothing, fyi.
Old 09-08-2006, 10:27 PM
RonP's Avatar
RonP
RonP is offline
Passenger cracked, no mushrooming.
Old 09-08-2006, 10:47 PM
HEMI-MINI's Avatar
HEMI-MINI
HEMI-MINI is offline
I thought I read some place that MINI made minor design changes that showed up in the 06's to prevent this from happening?
3k, 17" RF's....no issues
Old 09-08-2006, 11:03 PM
M7's Avatar
M7
M7 is offline
FYI.....
Got a call yesterday from a GP owner who had less then 1300miles on the car
with driverside mushrooming
He wasn't to happy to say the least. And yes he got some SRP's.
Peter
Team M7
562-608-8123
Old 09-08-2006, 11:13 PM
HEMI-MINI's Avatar
HEMI-MINI
Originally Posted by M7
FYI.....
Peter
Team M7
562-608-8123
Well MINI did make the suspension on the GP's even more stiffer then your standard MCS and MCS JCW. Too stiff of a suspension will do such things but the driver I believe could be part of the problem. Try to avoid the potholes! These cars were not designed to take potholes very easily like my HEMI powerwagon for instance. If you can't avoid the landmine...pray!
Old 09-08-2006, 11:56 PM
caminifan's Avatar
caminifan
Originally Posted by HEMI-MINI
I thought I read some place that MINI made minor design changes that showed up in the 06's to prevent this from happening? [Emphasis added.]
True (about the '06 design change); but it didn't eliminate the problem, as some '06 owners have reported cracked/torn strut mounts.
Old 09-08-2006, 11:58 PM
caminifan's Avatar
caminifan
Well MINI did make the suspension on the GP's even more stiffer then your standard MCS and MCS JCW. [Emphasis added.] Too stiff of a suspension will do such things but the driver I believe could be part of the problem. Try to avoid the potholes! These cars were not designed to take potholes very easily like my HEMI powerwagon for instance. If you can't avoid the landmine...pray!
Plus, 18 inch wheels, if memory serves....
Old 09-09-2006, 07:03 AM
erickvonzipper's Avatar
erickvonzipper
erickvonzipper is offline
I've been watching discussions like this with interest during the last two weeks.
Hmm, yes, those poll results are less than accurate. Of course very few cars with 18 and 19" rims have these problems. That's because there's a lot less of them out there to begin with.
My MC, with stock suspension and 16" RFs, has slight mushrooming on the right (passenger) side. That's because that side of the car takes all the abuse. The right edge of the road is where all the damage is from run-off and poor drainage. I remember a couple of teeth-rattling hits my car has taken on that side. No wonder there's some mushrooming on that side.
There's a set of M7 tower plates making their way to me as we speak.
Old 09-09-2006, 07:59 AM
GoodFinder's Avatar
GoodFinder
Hey There!
My GP has a slight upward crease about two and a half inches long in the driver side top surface. My MCS (with over 25,000 miles) has totally smooth perfect top surfaces both sides. I know how to drive, I avoid potholes, I've owned many cars over the years and this "mushrooming" is a new one for me. I think what got my GP was a "hidden" expansion joint in the road on Route 66 during MTTS. Yes, I have a set of M7 SRP's coming in, too, putting them on next week after I massage the crease back into submission!
Quick Reply: Poll: Mushrooming/strut mount failure data collection
