Moon Wheels
Moon Wheels
I am looking for a set of wheels? hubcaps? to go over a set of steel wheels? that are called moon wheels. They look like the ones on the old VW's. Has anyone put these on their MINI'S? I saw some pics with them on and it gave the car a real neat retro look......I mean it really changed the entire appearance of the car. Any info or pics if you have these would be great!:smile: Thanks......
These guys do custom wheels. Maybe they can help you.
http://www.stocktonwheel.com/smoothies_wheels.htm
Originally Posted by jds
Would it be possible to order a set of the MINI steel wheels used on MINI ONEs and then find an appropriate hubcap? My recollection is that ONEs use a full wheel cover, so that might not really be the look you're going for.
http://www.hubcapmike.com/smoothie_hubcaps.html
or the google search page:
http://www.google.com/search?sourcei...n&q=baby+moons
I know where to order them from, I was wondering if anyone had done it yet.
http://www.mooneyesusa.com/catalog/p...2d9bc1722968b9
http://www.counterfeitmini.com/
Been done some time ago.. as reported on the Fake Mini thread.. mine is on post 19
https://www.northamericanmotoring.co...highlight=fake
Well, I called Stockton Wheels, where these were listed and they don't come in our bolt pattern. Dangit!! Anybody else know where these might be available?
Unfortunately, the cars that are going to have steel wheels with a 4x100 bolt pattern are going to be old Japanese and possibly European cars, and they tend to have centers that have ventilating holes in them - they went to disc brakes sooner than American cars did. Also, the steel wheels that are available for newer foreign cars tend to be designed with centers that don't accept hubcaps. Also, it seems that until recently, most smaller cars were using 13" and 14" wheels, especially the lower line models that would use steel wheels. If you see a four-lug car running a 15" steelie (or alloy, for that matter), it's probably got the larger 4x100 pattern.
You might also check with Tire Rack. They do snowtire sets, and they *might* know of a wheel that would work.
I'd like the same thing, myself, actually, as I'd love to have a set of chrome wheels with '50 Mercury caps and wide whites to put on my MINI when I go to rod shows.
I have had a set of steelies for dedicated winter tires since fall of 06 for a a 2005 coupe. traded that car for an 09 clubman and have maintained the steelies for my snow needs. from the very start, I wanted a more refined look than the bare tirerack rims, do I searched and picked up a set of 4 chromed smoothie caps from hubcapmike.com
look under "vintage caps" and smoothies by size. they were about $100 delivered. the weight and quality of these moon caps was pretty good, and they mount to the tire rack rims well. but after a few seasons in salt belt weather, the plating pitted and grew rust.
this past fall, I ordered a set of hubcap mike's pop on racing disc wheel covers. these are made of stainless steel, so no plating failure will occur. no rust either. the pop on spring mounts are really good quality. these caps sit proud of the rim and completely cover the air filler stem. it is a startling look. i think it complements my PW clubman really well. got a compliment from a gas station attendant who said they made the car look like it was hovering!
To do it right you'll need hub adapters to adapt new vintage wheels they are selling for hot rods and such then you could get the hub caps and trim rings to fit the wheels. And the proper wide white walls Coker Tires would be a good start
12-23-2015 10:36 AM
SosoMINI
11-22-2015 03:17 PM
