Mini Cooper 2014-Present: Decal Modifications
Emphasizing the clean body lines of the Mini Cooper couldn't be easier by using stripes and paint decals.
This article applies to the Mini Cooper (2014-Present).
Mini Coopers are feisty little vehicles from Britain that have achieved a cult-like following among consumers. They have F1 racing influence combined with rally cars. Their unique size and maneuverability make them an excellent vehicle to zip around town or on the track in. They have unique styling when it comes to their exterior and often you may see racing stripes, the British flag, or other decals. These are considered "accent" mods and simply bring out the style and flair of these cute, zippy vehicles.
There's no limit to what part of the vehicle one could cover with a decal. Many enthusiasts opt for the roof and/or the hood. Some prefer to put decals on the doors on both sides and maybe even continue the graphic through the fenders. One can even wrap the side mirror covers with an accent color or scheme. With what's available on the aftermarket sector for automobiles today, the possibilities are endless for a truly unique look.
Decal Modifications
Learn about the different options available when considering adding decals or graphics to your Mini.
JCW Pro Mirror Caps
DIY Cost – $139.99
Professional Cost – 1 hour labor minus parts
Skill Level – Easy; requires removal of old mirror caps and replacement with aftermarket units.
Applying these side mirror decals to your Mini can add just enough spiciness to your Mini without going overboard with pricey changes. These are quick and simple to put on and can be just as easily switched out to keep your Mini as unique as your changing style.
Roof Decal
DIY Cost – $157
Professional Cost – $325 for labor and decal installed at the dealer
Skill Level – Moderately Easy; will require patience, as you will need to use a squeegee to remove any and all air bubbles when applying the material to your roof.
These are more for the owner who either wants to work with a bigger canvas for their graphic or just wishes to add something without taking away from the normal part of the exterior.
Hood Stripes
DIY Cost – $35-45
Skill Level – Easy; besides trimming to size, making sure the hood is clean and dry is the only important factor.
This is the more popular decal modification. Hood stripes can be found in both vinyl or magnetic strips. Either application is easy to do with your own two hands. Positioning and trimming to size will be the hardest parts of this modification.
Pro Tip
A clean surface is key for optimal adhesion. You'll want to make sure the surface you are applying vinyl to is not only clean, but 100% dry.
Racing Stripes
DIY Cost – $256
Professional Cost – 1-2 hours labor plus parts
Skill Level – Moderately Easy; very similar to applying a roof decal.
These give your Mini racing flair and and can piggy back or be an alternative to the stripes shown above.
Related Discussions
- Roof Decal Options - NorthAmericanMotoring.com
- How Much to Pay for Roof Decal Installation? - NorthAmericanMotoring.com
- British Flag Roof Decal Installation - NorthAmericanMotoring.com
- Mirror Cap Installation - NorthAmericanMotoring.com
