Oh Dear
Oh Dear
My engine light came on and they're telling me it's due to bad compression in one of the 4 cylinders. 45 pounds instead of the required 90. They're considering replacing the whole engine and tell me this is a one in a million thing. The MINI is one year old with 14,000 miles. Anyone else have this problem? Anyone who can offer advice?
I would not worry about needing a replacement engine... happens all the time with Porsche (and to a lesser extent BMWs).
The Enginerds want to see "what happened" and you get a free (lower mileage engine
I wouldn't worry about "non-matching numbers" as the factory is making the swap, and well, number's matching just doesn't matter to the next buyer like it would if your Mini was, say, a 1964 Corvett Fulie.
Good Luck, and enjoy the loaner in the mean time!
https://www.northamericanmotoring.co...ht=head+gasket
If the engnine only requires a gasket, then it only needs a head gasket. For their effort, they can practially change the engine. If you let them replace the gasket and it is not better, then you'll have firm footing for a replacement engine. Suggest they check the mating surfaces prior to installing the new gasket. If something is wrong with them, a gasket may not help.
midnightblackjcw
09-21-2015 10:51 AM
