Power Steering Pump Quits
Old 11-21-2009 | 08:34 PM
jgLabrown's Avatar
jgLabrown
My first post, although I'm not terribly new to Minis with a 1965 Traveller and a 2002 BMW Mini: today, in the 2002, the power steering went out as my wife was in a fairly-sharp (80 degree) right turn with oncoming traffic. No smashups but a couple of close calls. When she returned home I checked everything over and found no obvious discrepancies (good fluid level and electrical and mechanical connections ok). In surfing the internet, I then found a large number of similar power steering failure complaints (mostly in the UK where they've had more time with the car): it appears that the pump itself is faulty. No recalls, however, as BMW's crack legal staff seems to be on the ball. The car has a little under 50,000 miles.
Old 11-21-2009 | 08:46 PM
not-so-rednwhitecooper
The pump itself almost never fails, the electronics on the motor and motor itself are usually the culprit.
Old 11-21-2009 | 08:47 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yup sounds like your P/S has died, this is a pretty common problem. A new pump will fix it, and the newer pumps are also quieter.
http://www.waymotorworks.com/product...6&cat=0&page=3
Old 11-25-2009 | 10:42 AM
DMBFan2's Avatar
DMBFan2
My wife has on 03' with 42k miles on it and her PS intermittently goes out. It has scared the hell out of her more than once with a few close calls. Guess a new PS pump is in the works.
Does anyone know of a good pump that is RELIABLE? (since BMW can't seem to manufacture reliable Mini parts)
Is it worthwhile to have the old PS re-manufactured in case my other Mini PS pump starts going out?
Old 11-25-2009 | 11:06 AM
DMBFan2's Avatar
DMBFan2
While looking around for a PS unit and an upgraded PS fan (one that moves waaaaay more air) I came across this:
http://www.bbc.co.uk/blogs/watchdog/..._failures.html
I guess we're not the only ones complaining.
Etrain
16
08-05-2024 05:37 AM
Manny_cooper
09-10-2015 12:09 PM
HaveATank
09-04-2015 09:04 AM
coachvminis
08-25-2015 07:58 AM
minipopkart
08-13-2015 06:22 AM
Quick Reply: Power Steering Pump Quits
