Question
Vendor
Depending on what Ipod connector you have to the car. Most shut off with the key off, so leaving the ipod connected won't hurt anything.
As for running the A/C all the time. It won't hurt the car, but it will cost you fuel mileage. Also I suggest shutting off the A/C about a minute before you shut off the car. Keeping the fan running when you shut it off will dry off the evaporator and keep mold and mildew from growing on it. That way your car won't have odors with the A/C on, and you won't be breathing mold which isn't good for you.
With the MINIs the battery shuts off about 15 minutes after you close and lock the car doors so leaving anything on will not drain the battery. I also discovered the other day that even if you leave the keys in you only get about 10 minutes of running the outlets before they shut down as well!!
I leave my headlight switch in the on position all the time and it doesn't drain the battery in the least.
Thanks for the correction!
Grizld700
12-30-2015 10:47 AM
Navigation & Audio How much power do you get through the Y-cable--and can it be increased?
twriter
10-02-2015 03:14 PM
