'02 Silk Green 5 spd.
I have found an '02 Mini with 44,000 miles. The interior and body are in very good condition. It runs well and the 5 spd. shifts smoothly. There no observable fluid leaks. What should I have checked in the front end? I know there have been issues with sway bar bushings and CV joints. Please relay anything you would have a mechanic check out if you were considering this vehicle. The asking price of $11,900 seems high to me. Thanks for your help.
I memory serves me correctly, the early Justa's had a Midlands 5 speed that had 1) Plastic bearing seals which would fail in cold weather allowing the fluid to leak out with resultant catastrophic tranny failure, 2) loss of drive on the diff due to the outer ring separating and 3) weak syncros on 1st and 2nd.
Midlands replacement runs between 2k-4k dollars.
For the kind of money they're asking for the Silk Green, I'd take it to a MINI dealer for an inspection and evaluation.
And the price is much to high. But then again, I don't know what options are on the MINI.
Or save a bit longer and find a low mileage '06 MCS and you'll be getting the best MINI made.
Just my two cents.
....Les
Just my two cents.
....Les
BucksCountyR57
R57 :: Cabrio Talk (2009+)
11
09-30-2015 02:11 PM
MCarrera9
09-22-2015 09:42 PM
