Tire and water pump questions
I have had my 02 mcs since new and had only the minor problems with coolant tank leaks and a few others. Now I have "the leak" the water pump O ring leak. should I just clean up all the parts, replace the rings and hope for the best or is there a suggested improvement that I haven't found yet.
Second question is about unusual tire wear, A groove has worn on the insde corner of all four tires down to the steel belts. I cannot find any spot that they have rubbed on the car, Has anyone ever heard of this.
thanks for the input. Both my wife and I have 02 Mini's and have been fortunate with both. She's at 130k and mine is 71k. I just replaced my clutch since its so far apart for the coolant leak and was surprised to see the original was in fantastic condition. I debated putting it back together with the old one but decided against it. Having the engine out require an alingment after assembly as I understand so this with the new tires will hopefully fix the tire wear issue. One more word of warning to others. My car had a sudden evacuation of the A/C refrigerant last summer due to a short piece of rubber line rubbing through wear it contacted the clutch cylinder hard line near the front of the trans.
theateist
07-02-2017 02:21 PM
gmonde
09-08-2015 06:37 AM
Lex2008
08-16-2015 08:33 PM
