just got.....
Congratulations on your new purchase. ENJOY!
I hear that a Cold Air Intake is a nice addition to an R53, but I'd go to the Modification section of Generation 1 MINI's to ask this question and do research.
If you are on a tight budget modding can be a frustrating activity. Watching the Classified section can save you some $$.
Good luck!
Good luck!
For an R53, the first mod should always be a smaller Supercharger pulley.
Check out http://www.waymotorworks.com/wmw-pulley-package.html
Also a cold air intake, I recommend either Alta:http://www.altaperformance.com/produ...ld-Air-Intake-
or DDM: http://www.waymotorworks.com/ddm-int...per-s-r53.html
The Alta is the loudest, which is a beautiful sound. Sounds like Darth Vader mixed with a rabid Vacuum cleaner and a woman having a crisis(Top Gear, hehe.)
Also take a look at a One-Ball exhaust, if you want the stock system a bit louder:https://www.northamericanmotoring.co...clips-etc.html
Most shops charge like $50-75 to do this.
Those are definitely the cheapest mods with the biggest effects(The CAI and One ball won't provide a ton of power, but will provide a ton of awesome noise).
Good luck!
Good luck!
I got my pulley/cold plugs/belt from Way but haven't installed them yet. That's about $200 and install (if you don't do it yourself) is quoted around $300-400 here.
I also highly HIGHLY suggest a minifini.com cupholder or two.
