New 2011 MCS Owner...going to Minis on the Dragon in MAY!!
#26
#30
OK...I couldn't wait any longer.....I just bit the bullet and put the NM Engineering Cat back exhaust on my VISA card!!
I can't wait till it gets here next week.....
If it sounds anything like this one it should be Sweeettttt.
I wanted deep and fairly quiet (Im 38..LOL) and after all the searching and discussions I went with NM.
http://www.youtube.com/watch?v=vZjO0bZG-go
Larry
PS_--Also staying at the Microtel in robbinsville for the MOTD
![tongue](https://www.northamericanmotoring.com/forums/images/smilies/tongue.gif)
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
![Grin](https://www.northamericanmotoring.com/forums/images/smilies/grin.gif)
Larry
#32
Do cat-backs give you CEL's? The deepest plunge I've taken in performance mods is the NM Engine Torque Arm Insert. At The Dragon, Way is going to install the WMW Performance Blow Off Valve. That will be it for me for awhile. I need to replenish my bankroll! Concerning the "deep and fairly quiet", I'm down with it... I'm 47.
Sarah, no idea. Good luck and if we ever meet, no hand shakes or hugs!
#33
Larry, that sounds AWESOME. Since I'm even older than you, maybe I need that one as well. Any comments when you were researching on the drone factor? I don't mind a bit of drone, but it gets on my daughter's nerves when she has to ride in the backseat.
I currently have a folder on my desktop of all youtube videos of various exhausts. So far the one you just linked to is my favorite, hope it's not out of the park expensive.
Annette
Annette
#34
sarah it may be best if you post in a more specific forum and start your own thread. If you want to send me a PM with the year of your MINI I'll be happy to point you in the right direction to find the answer.
It will also help if you fill in your location in your user profile then people can recommend MINI service folks in your area.
Annette
Annette
#35
#36
Drone is going to be an issue with any system, but luckily, every MINI I have ridden in with an exhaust had drone at RPMs higher than cruising range on the highway.
I am stuck between a custom Magnaflow...this one actually...
http://www.youtube.com/watch?v=6cFYf...&tracker=False
http://www.youtube.com/watch?v=Yh2GK...&tracker=False
Or, saving up for a Quicksilver.....
http://www.youtube.com/watch?v=pSamdpzfpZk
Here is a local Tarheel person with a quicksilver...
http://www.youtube.com/watch?v=X_syPxk59N0
#37
Annette, I spent the past two weeks at work reading and listening to videos of exhausts before choosing the NM Engineering. I LOVE music and have the IPOD interface on my HK system. I also suffer from hearing loss from being stupid as a teenager and listening to a "walkman" (wow Im old) while mowing grass for summers. Combine that with owning a Harley with pipes for a few years, and you can see I'm past my Loud Muffler phase...lol
I decided on the NM based on its lower, deeper sound and reports of minimal drone. ALL mufflers will drone a bit if you are cruising the highway in 6th gear and start to go up a grade, so I am told. The most perfect muffler is the JCW from what I gather. I was going to consider a JCW stage 1 kit and be done with it, however it will cost $2600 in 2011. yess it gives you the badges and a ECU tune, but all I want is the sound and a little more low end torque.
The NM muffler is supposed to sound real low and mellow while you are cruising around below 4,000 rpms. If you nail the gas it will open up and make people notice. Thats what I wanted.
So for $1200 I am going with a NM cat back ($800 from outmotoring.com) and a Defenders of Speed intake ($320). I also looked at a lot of intakes and I want to be able to get performance, but not too loud. The DoS intake I ordered can have a butterfly valve "silencer" installed before shipping as an option. This butterfly stays closed below 3500RPMS so the intake sounds almost like stock, but still breathes better. However, if I stomp the gas it opens the valve and you can hear the turbo suck and blow
If I need to make it even more quiet for a long trip they offer a Plug to install and baffle the air intake. THat plug makes it almost as quiet as stock.
Hope this helps in anyones buying decisions.
![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
#38
Yes, it does! Thanks. I also love that you can get if from outmotoring, any business I can do with them is great with me.
I had the Alta CAI on my '06 and loved it, most especially the sound. I don't quite understand the intake and turbo thing. I've had people tell me most emphatically you can't do an intake on the turbo MINI just the supercharger. And then been told the opposite.
I can do the exhaust now and add an intake later if I want, right? I'm not sure I need to spend another $500(with install) right now, but had put the exhaust in my budget from the get go.
Annette
Annette
#39
You can do the intake on both! If you do it with the turbo, you can hear the turbo spool up and blow off really well. I got mine for that exact reason! My DDM Street Intake only costs me $190 and I got free shipping from Aaron at OutMotoring for it!
http://www.outmotoring.com/mini-coop...et_intake.html
#43
I second Laardillas post about the DDM Intake. It is a good system.
Annette, your turbo will benefit from a new intake,just like a super charged engine would.
From what my service MGR and all the posts say, I would avoid any system that uses a foam/oil filter. the Mass Air Flow sensor is easily contaminated and the oil seems to be the culprit.
Annette, we are arriving at about Noon on thursday at MOTD..where can we find you so we can meet and I introduce you to my wife?
Larry
Larry
#44
They show a foam one, but they sent me a K&N filter. I have not had any issues with my oiled filter, but I also use MAF cleaner on my sensor. It is an awesome cheap mod. You can also buy the completely open hood scoop insert from minifini. It comes in chrome, but you can spray it black. It lets in a ton more air.
#45
Larry
Larry
Laardilla, do you run an open scoop? I would worry about too much ash and trash getting in the engine compartment. I've thought about using a Dremel to open a few more holes in mine though.
#46
These should fit on just fine, as well.....
http://www.aemintakes.com/dryflow_air_filters.htm
They are side branch of K&N and require no oil....I am definitely upgrading to one of these soon....They are on Amazon for about $50...
I wanted to go with the DoS, but did not want to cut a hole in the bulkhead or buy the seperate bulkhead replacement panel...
#47
#48
I have the stock insert still. I am getting the minifini one soon though. My engine bay gets so dirty with the one I have, I figured it could not get any worst....haha...
http://www.minifini.com/ShopDetail.aspx?id=60
#50
Annette
