silky green 03 cooper
I just picked up my first mini cooper about a week ago, it's a 2003 cooper base with the cvt/shift tronics tranny. so far I've done mostly emergency maintenance on the car as the last owner wasn't smart enough to replace the ORIGINAL air filter with 107,000 miles on it. additionally it hasn't had any of it's big services done at a bmw/mini dealership so there's no records of maintenance. hopefully i can learn everything i can from you guys.
btw, i think the dealership i bought it from replaced the oil with traditional oil. can anyone enlighten me if that's a huge problem?
I don't think it's a huge issue. You may want to replace with synthetic oil right away, though. Don't forget to check/change the cabin air filter, along with brake fluid and coolant, which should be changed every two years. Silk green is a great color. Sounds like this car is in better hands now...
on
Welcome to the forum. I would get the oil changed to synthetic very quickly with 107K you could be asking for engine trouble. Also the CVT transmissions can be a trouble spot, keep your eyes on it and treat it gently. If it goes bad there is no fixing it and a replacement can cost as much as $7000.
+1 on the CVT fluid change, although neither of our cars is a CVT model, I have heard that changing the CVT fluid regularly is a good idea. It takes a special fluid (not ATF) so have it done by somebody who knows what they are doing.
Silk Green is an awesome color- my wife loves her Silk Green/Silk Green MINI!
Val
Val
kurosh
08-27-2015 11:54 AM
