NEW MEMBER (looking for modification advice)
Hi everyone!
I am a new member from Tucson Arizona. I have owned my r53 for about 2 years. I signed up mainly to get some good advice on my future plans for upgrading my Mini.
This is everything i have done to my r53:
-Alta 15% pulley kit
-Konig Feather 17" rims
-Alta CAI
-One ball exhaust mod
-Evotech ECU upgrade
Thats about it so far. My next one will probably be a rear sway bar.
I'm happy to finally be a member of this forum, it has helped me out a lot in the past!. I will try to attach some pics of my mini.
https://www.northamericanmotoring.co.../ppuser/121767
https://www.northamericanmotoring.co...ze/big/cat/500
THANKS!
-Eddie
-Alta CAI
THANKS!
-Eddie
new member too
Hi eddie ,im pedro i got an mcs jcw '03 with cai , bigger ic, msd ignition, beru coolder plugs, im going to put on a 15% pulley an a header, since you allready have the pulley and the ecu upgraded why dont you try the blue inyectors(jcw),that willbe my next step, take care.
If you install larger injectors, it would be in your best interest to get a tune. I'd suggest strut tower reinforcing plates and new engine mounts all around if you don't have those yet...next on my list is the plates and after that a BSH lower mount...then I'm thinking a DT bypass valve, then its on to injectors and a tune. Also, welcome! I'll give all the advice I can, but truely, I'm a bit new to the MINI scene as well...I only got my R53 in July, but I've already had the whole thing apart multiple times I just finished tracking down the elusive "clunk" that its had since the day I bought it...turns out some moron didn't torque down the front passenger brake caliper bolts and the caliper had some play in it...
