New Here- Fob Question
Im Don hi. I live in Portland Oregon and am enjoying my new mini clubman- s
Im sure this web sight will be entertaining and informative, looking forward to chatting with fellow mini enthusiasts-
My Fob had worked once to start the engine without the fob being keyed-
I cant seem to do that again, is there something special that needs to be
done first???
done first???
How old is your fob? It may need a new battery. My fob on my newer 2013 gets recharged while inserted in the ignition. Perhaps yours is similar. It also will not work if I have it partially in the ignition (i.e. it either has to be fully engaged or not at all). Another possibility is your fob may need to be reprogrammed, which a MINI service center can assist with.
on
If you have comfort access it does not charge in the dock, it will have a replaceable battery. If you do not have comfort access you will not be able to start the car without the fob docked. I have heard that if you dock the key and then remove it you can start the car. I am not positive on this.
Spice Orange is correct -- the owner's manual states that comfort access fobs have a replaceable battery. (My MA & service advisor both told me that my key was rechargeable. Bad info apparently.) Sorry to cause confusion. So, a new battery might be in order as described initially. Apparently, malfunctions can happen with radio wave interference -- fob close to a mobile phone for example. Let us know Don how it turns out in the end.
