r53 track mini...help
thinking about buying this mini for track and just fun tinkering. Its got 60k miles. here is the build sheet. Price is $12.9k
let me know if this is a good deal or if I should negotiate.
Looking for some advice.
much appreciated.
this should be the full build sheet...( im double checking)
motor has stock internals ,( it was tuned and have the name of tuner somewhere... i think she had a built motor blow on a different tune and pully...i'll double check that also)
has torsen lsd which works very well on the street and track
yes to short shift kit listed below...
15% Reduction pulley
165 hp to the wheels
Oil cooler
Suspension, Brakes, Transmission, Exhaust
Cross Competition Coilovers
o Swift springs in rear
‘05-‘06 model years transmission
Clutchmasters Stage 4 racing clutch with aluminum fly wheel
Lower rear control arms
JCW front brake kit
o Hawk DTC-60 brake pads front and rear
Stainless steel threaded brake lines
New front wheel bearings
Newly rebuilt front axels
Eisenmann 1 ball exhaust
Exterior
JCW front bumper
SSR Type CR 17 x 7.5 w/ Nitto NT-01 215/45-17
o Second set of SSR’s available w/$1000
APR Carbon Fiber wing
Front windshield replaced year ago
Front license plate holder (will be provided but not currently on car)
Interior
Sparco Pro 2000 Plus seat in red w/ Schroth 3”-2” lap, 6 point harness in red (drivers side)
Corbeau Forza seat in red w/Schroth 3” 6 point harness in black (passenger side)
6 point Safety Devices International cage in red
o Harness bar
o Adjustable driver seat support
Rear seat delete
Momo suede steering wheel
Scan Gauge II
Boost gauge
Oil temp gauge
Craven shift **** in red
Craven short shift kit
Additional Info
Car has 62,xxxtotal miles
All work done at MINICorsa
No cooling issues on track, both water and oil, even in 108 degree heat
Oil changed after every 2nd track day
Car has full interior excluding the seats. All body panels and carpet.
Car is registered and fully smogged. Cats have not been removed.
Tags are good Clean title
i think the stock seats and rear belts are around somewhere
much appreciated.
Oil cooler
JCW front brake kit
Exterior
JCW front bumper
Interior
o Harness bar
Rear seat delete
Scan Gauge II
Boost gauge
Oil temp gauge
Additional Info
