First mini - good bye cvt, hello 6 speed
I am a new mini owner.
You may ask, how did I get here?
My daughter will only drive an automatic transmission, I purchased a chili red 2003 Cooper R50 with a cvt transmission. It has 87,000 miles. Two months after the purchase the cvt failed which is evidently not that uncommon.
I found your forum a valuable resource as I researched my options. I paid $7k for the car and did not want to pay $7k with installation for replacement cvt installed.
I found a local 6 speed from a 2006 R53 in a local junkyard. The dealership where i purchased the car is contributing $1200 to what will be about a $2500 project for parts only. .. As is no warranty so I was happy to get some money ... I plan to do all the work myself. My first purchase was the bentley repair manual.
From the junkyard I will purchase used 6 speed, manual shift pedal assembly, clutch master and slave cylinder, trans mount, shifter assembly and cables for $1,300.!
From local auto zone left and right cooper s drive lines for $150.
From way motor works a new clutch, pressure plate and flywheel for $500.
way motor works will reprogram the ECM $450 to accept the 6 speed instead of the cvt automatic.
My daughter doesn't want a manual transmission so I will turn it into my daily commuter.
I posted most of my cvt to manual 6 speed at www.psmini.org
Our local Seattle area mini club.
A long project, mostly due to lack of time to commit to the project due to other life priorities.
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
