hi from the "502"!
hi from the "502"!
been getting on the forum for a while to look at how to threads and decided to join a while back. glad to be on here and just wanna let everyone know that this place has been my go to source for advice, tips, and instructions on just about everything mini.
currently own my first mini and its an 07 cooper s in mellow yellow. bought her about 7 months ago.
current upgrades are:
alta intake
alta hard pipe
alta boost tube
alta bov/recirc valve spring upgrade
new timing chain, guides, and tensioner
front/rear speaker signal swap (sounds sooooo much better)
and many more to come!
Glad to be here!
-brad
alta intake
alta hard pipe
alta boost tube
Glad to be here!
-brad
I wish I knew what the first owner did to Blue Meanie. By what I see, a nice mini radio attenae and new thermostate with housing just before got her.
What I want: rear sway bars
Winter tires
Smaller pulley (unless that was done...man it's quicker than I expected)
Row of fog lamps on the front. Can I do this mod hooking into the open space on the dashboard for the switch? Then would look really cool.
Watching you all for more mods!
What do I do with the DSC switch? Is it on or off when light is off?? I'm going back and forth with my son, the gear head on this.
Winter tires
Winter tires
Winter tires
As for the DSC light, here's my layman's interpretation: when the dash light is unlit, the DSC is engaged & active. If during driving you hit a wet or slick spot that causes the car to lose traction, the lamp will light up momentarily (this brief flash means DSC has done its thing). You can also use the toggle to turn the DSC off during regular driving if you wish. When doing this the DSC dash light will stay lit.
I hope I explained this properly and clearly, but I trust another member will correct me if not.
fridayxiii, ill post a few pics up as soon as i can. right now shes really dirty because of snow and salt on the roads. makes things a pain to keep clean. but when i can ill post a bunch on here.
also i plasti dipped the wheels(factory for 2 or 3 more days) headlight and tail light rings, front and rear emblems, door handles and side scuttles (i think thats what theyre called). also i made an antenna delete. i dont have gps or satellite radio or anything so i dont need it. and the radio reception wasnt effected at all. but ill post all that in the pics as well as the new wheels when i get them!
The most common pulley reductions are 15% and 17%, tho some run 16%, and a few 19%. Stock JCW had a 13% pulley. As for what size you have now, it can be hard to tell. Here's a post from another member that IMO sums it up well: https://www.northamericanmotoring.co...313-post4.html
The First Gen forums are a great place if you need more info any of the above.
Hope this helps!
