viiibbbrrrattion
viiibbbrrrattion
So, here's the deal. Picked up a 02 mini, 95000km. Had to put new tires on, but several things had been done already with records. New clutch at 85000km. I had all fluids changed out. Car shifts beautifully. Problem is, when the car gets warmed up after 15, 20 minutes, you get awful vibration engaging first gear. I don't believe it's clutch related at all, but difficult to find "sweet" spot to avoid it. Thought good possibility related to engine mounts. Just had those replaced today. Same scenario. Disappointed to say the least. The only good thing that came of this is that the passenger lower mount had no hydraulic fluid in it. Is it possible things get better when mounts break in? I don't mind spending, if I get results.
Yes, starting out in first gear, but only after the car has been driven about 20 minutes. No signs of anything leaking, I had all fluids replaced just after I bought it. Clutch is only 10 000 km old. Shifts beautifully otherwise. Idiot proof for that first while, then it seems you have to pay attention, rev higher or start out in 2nd to avoid the shudder.
See, and that's what's funny, because mine is the opposite. Starts when it's warm. Now, on a good note (fingers crossed). I went back to my mechanic, and when the young observing apprentice was unbolting the airbox so we could look at the tranny mount for damage, he noticed the clips were gone or broken off of the lid. Therefore, not sealed. I taped it up tight temporarily and the shutter seems to have gone away. Hmmm
