still hoppin along HELP
Have fixed quite a few things on this old girl, but she's still hopping. First suspect of wheel hop when we got it was the flywheel, however, apparently, it was replaced with the clutch. Suspected a bad rear wheel bearing, I was right, it was starting to grind. Replaced both rear bearings. Replaced all 3 engine mounts. 2 were bad. Seemed as though hop was gone. Nope. Might have to drive longer before it happens, so it seems all these things were contributing factors. I am suspecting a bad front bearing. No play, and hard to hear even with scope because of the noisy-*** performance muffler. Would a bad front bearing, as it heated up, contribute to the hopping?
