New 07 R56 Cooper
Old 04-17-2016, 07:17 AM
pluffmud's Avatar
pluffmud
pluffmud is offline
New 07 R56 Cooper
98000 on the clock, Lightning Blue/White, bone stock as far as I can tell. Interior/exterior in excellent shape, good service records.
I tinker with older BMWs (E24, E28) - it appears elbow room is minimum underneath the Cooper.
I am glad this forum is here - I will keep reading until I have an intelligent question.
Old 04-17-2016, 02:32 PM
Mini3333's Avatar
Mini3333
Mini3333 is offline
Pictures? ...S or non S? (N12 or N14 engine?)
Old 04-17-2016, 03:41 PM
pluffmud's Avatar
pluffmud
pluffmud is offline
07 Cooper - N12
Will post some beauty shots after I clean her up and put new badges on tomorrow.
Old 04-17-2016, 03:50 PM
Mini3333's Avatar
Mini3333
Mini3333 is offline
Originally Posted by pluffmud
07 Cooper - N12
Cool...I'm glad to hear that you got the base model...a lot less problems as compared to the N14 engine.
I look forward to seeing the pictures!
Old 04-17-2016, 04:11 PM
pluffmud's Avatar
pluffmud
pluffmud is offline
Don't think I qualify for the timing tensioner fix, though - unless the parameters have changed. Service records do not indicate it has been done; it's not an issue now - hopefully if I do the oil changes every 6000 or so and keep her in fighting trim it won't be.
Right now just reading and poking around. Slight intermittent oil smell from engine front - oil level remains consistent, no obvious leaks. Crank seal, o-ring, gear oil - won't know until I can get her up in the air again this week.
Bentley on order.
Old 04-17-2016, 04:23 PM
Mini3333's Avatar
Mini3333
Mini3333 is offline
The base model has had very few probs. Enjoy your new car!
Old 04-17-2016, 04:39 PM
pluffmud's Avatar
pluffmud
pluffmud is offline
Thank you.
Old 04-18-2016, 07:44 AM
ECSTuning is online now
Received 2,096 Likes on 1,870 Posts
Yea, its does not have the turbo problems, but I would check the thermostat housing and the water pump and if it have been changed.
Let me know , here to help.
Old 04-18-2016, 05:09 PM
pluffmud's Avatar
pluffmud
pluffmud is offline
Those done - I do need a windshield cowl set - does your kit contain all the parts in the link? #1 in the schematic is deteriorating and needs replacement - thanks!
http://www.realoem.com/bmw/enUS/show...diagId=51_6604
Old 04-19-2016, 05:15 AM
Thats under the cowl. Not in the kit. 51312756196
https://www.ecstuning.com/Search/Sit...h/51312756196/
The upper weather stripping that deteroated part of the man cowl on the end.
https://www.northamericanmotoring.co...ield-cowl.html
Windshield Cowl Cover Kit 51132751210 51132751211 KiT
https://www.ecstuning.com/Search/SiteSearch/51132751210KT/
Old 04-19-2016, 09:33 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Welcome to NAM! Assuming this is your first MINI? If the service records don't indicate it, I'd probably do a coolant flush. The cooling system is one of those often areas that are neglected on MINI's. Otherwise, definitely looking forward to those pictures! We also have a lot of free tech articles on our site that can help along with this forum and your Bentley Manual.
888.280.7799 | 6am - 5pm PST
speedkills66
09-12-2016 07:37 PM
tmelsh
04-25-2016 09:36 PM
cb_smalls
04-16-2016 03:13 PM
Cobrasix
04-14-2016 01:45 AM
N2MINI
04-11-2016 07:24 AM
Quick Reply: New 07 R56 Cooper
