R56 from Temecula, CA
Old 10-25-2016, 05:30 PM
Mini Mania's Avatar
Mini Mania is offline
R56
Originally Posted by vincedprince
Thanks Mini Mania! Your inputs are very helpful!
Least I can say with this car... one issue after another. Soooo..... the clutch went out. LMFAO.
After changing the water pump with that fine piece from Mini Mania, took it for a quick drive around the block and started slipping. Gears not biting right away, clutch pedal vibrating, and a god-awful groaning sound when I gave it gas. Perfect... looking forward to a big job.
What clutch to get? Since I'll have the car on service mode, might as well change out the oil feed line and the water pipe behind the water pump. I can't believe why they used plastic for it. SMH. Any indications to find out if the thermostat wants to break as well?
So if I could get a link on the clutch, water pipe + o ring, and whatever else is a good idea to replace while I'm in there, will be much appreciated.
You're more than welcome!
  #27
Old 11-02-2016, 06:31 PM
vincedprince's Avatar
vincedprince
vincedprince is offline
And so it begins...
Gonna tear through the car and replace everything that needs to be replaced!
  #28
Old 11-02-2016, 06:34 PM
vincedprince
Took off the downpipe to work on the leaking oil line. I've been getting the dreaded 2885 code which I've read points to the wastegate. How should these things behave normally? It's open and loose. I could post a video of me jiggling it with my finger. Lol
  #29
Old 11-11-2016, 10:08 AM
vincedprince
Can somebody tell me what this is and is there suppose to be a gap? I stuck a ziptie in there for you to see the opening.
I was degreasing the underbelly to pinpoint other oil leaks and saw this. Underneath the transmission.
  #30
Old 11-11-2016, 11:25 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
it seems that the output cylinder clutch isnt aligned properly. loosen the nuts and realign it
  #31
Old 12-12-2016, 02:34 PM
vincedprince
Finally found time to work on the car again. Drive axles are out and everything else attached to the transmission. Could someone kindly direct me to procedure for subframe removal? Been following pelican parts tech articles but only show R53 for subframe.
Thanks!
  #32
Old 12-12-2016, 02:37 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Why do you need to remove subframe? At this point you should be able to pull the assembly out. Hopefully the nose is out of the way!
  #33
Old 12-12-2016, 04:15 PM
vincedprince
Was following diy tech info @ pelican parts. I was wondering if subframe removal is indeed a necessary step. The nose is off now. Lol. Took a break to take a pic.
  #34
Old 12-12-2016, 04:26 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Yep. That's it. Stap the engine and pull it out. Make sure to free the ac line at the compressor and the free the starter and the cables to the alternator.
  #35
Old 12-12-2016, 05:58 PM
AlphaQuad's Avatar
AlphaQuad
AlphaQuad is offline
Hi, I'm from Corona nice to see another socal MINI guy one here! Welcome!
  #36
Old 12-16-2016, 09:14 AM
vincedprince
Well this is a first... Green fluid started dripping out when I loosened the bottom bolt of the starter. Is that normal on these cars?
  #37
Old 12-16-2016, 09:17 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Nothing is normal when fluids start coming out of the car. on top of the started is a water pipe and is known to leak either from the pump side or the thermostat housing side. Prepare to replace it.
  #38
Old 12-16-2016, 10:17 AM
vincedprince
I have the thermostat housing and the pipe off already since it was leaking from the pump side. Probably seeped in there when coolant spilled over the place when I took them off. The green color threw me off. Makes sense to be coolant though... previous owner had yellow coolant in there. Yellow+ blue = green. Lol
Should have processed in my mind first before I posted. Lol
  #39
Old 12-16-2016, 10:18 AM
vincedprince
Originally Posted by alphaquad
hi, i'm from corona nice to see another socal mini guy one here! Welcome!
  #40
Old 12-16-2016, 11:16 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
With this freezing weather, i dont blame you brother lol
  #41
Old 12-22-2016, 12:46 PM
vincedprince
All this rain doesn't help. Makes me lazy to do any work. And since I don't have access to a crane or garage roof rafters (from the thread i read on here) to support the engine and tranny from above, behold... my rig. Lol
Finally got the transmission out. Had to lower the subframe a bit to clear but didn't take it off all the way.
  #42
Old 12-22-2016, 03:18 PM
michi1201's Avatar
michi1201
michi1201 is offline
Pretty ingenious. Hope all goes well and you're back in the saddle soon.
  #43
Old 12-23-2016, 01:59 PM
xmiggzx's Avatar
xmiggzx
xmiggzx is offline
Thumbs up on the plasti dip. Looks great!
  #44
Old 12-24-2016, 11:11 AM
vincedprince
Well....... should have checked first but I guess the clutch kit I got didn't come with an alignment tool. ��
Don't really want to wait for an online order since I'm itching to get this job done already.
Anybody on here has an alternative? Harbor Freight? Autozone tool rental? Suggestions on what you may have used before?
  #45
Old 12-24-2016, 11:16 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
I never used an alignment tool. Put new clutch same way you took the old one.
  #46
Old 12-24-2016, 11:36 AM
vincedprince
And somebody take a look at this for me. This is what my DMF looks like.
Tough love with this car ��
  #47
Old 12-24-2016, 12:11 PM
vincedprince
Badass. Lol. Just eye it eh? What's your opinion on the images of the flywheel?
  #48
Old 12-24-2016, 12:16 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Lol i guess so....for the plate, I'm not too sure how much meat you should have.
  #49
Old 12-24-2016, 01:50 PM
vincedprince
Thickness looks ok. More worried about heat spots.
Anddd... totally forgot to get tranny fluid! Great.
2 quarts yes? What do you use/recommend?
  #50
Old 12-24-2016, 04:45 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Back then i went to pepboys and the guy had me use royal purple w75. You can shop at rmeuropen.com and get manual trans fliud. Probably cheaper and more oem than royal purple
Quick Reply: R56 from Temecula, CA
