Hi from PA
Hi from PA
Hi, I recently (last month) bought a used 2011 Mini Cooper S. I thought the forum would be useful for some tips if I need them. It has about 84000 miles on it now (I drove it for a little over a 1000). So far I decided to preemptively: changed oil and filter (full synthetic of course), changed spark plugs to Bosch iridiums, changed serpentine belt, put on new brakes and roters (Bosch quiet cast rotors with Monroe ceramic pads and flushed out all the Dot4 brake fluid and replaced), Swamped the valve cover gasket as it looked like it had a very small oil seeping out, changed the halogen headlights to LED with resisters, changed both the engine airfilter and cabin air filter. Is there anything else that I should be looking into for needed maintenance ?
The car drove fine before the work butI figured since I was doing it myself and it really was relatively cheap parts I might as well replace early as im unsure of maintenance which was done on it.
Also is it supposed to backfire when i stick it in sport mode or is something wrong with MAF or O2 sensor?
