1st GearNew members: make an initial post and introduce yourself as you shift from Neutral to First Gear. Current members: meet some of the new members.
I have a 2005 r53 with a 17% pulley reduction. I received a few codes p0171, p0131, and p0455. I replaced the gas cap with oem, and o2 sensor with exact fit NTK sensor. Still receiving codes, could larger injectors be needed or possibly something else?
Thankyou for your time.
When you say that you have a 17% pulley, did you just replace the pulley and have gotten the codes? I've not looked up the codes, but I don't believe larger injectors will solve your problem. Did you put cooler plugs in?
