New-to-us R52
New-to-us R52
We picked up a 2006 Hot Orange R52 S this month with the manual transmission for our daughter. It has about 158k miles. We towed it back from IL to MI and set about correcting a couple of small items before putting it on the road.
My daughter helped me replace the Left and Right rear hard brake lines. We used copper/nickel lines instead of steel and replacement stainless brake line fittings. I was really surprised to learn that Minis use steel brake lines, as I hadn't encountered that in any of the other European cars I own or have owned (I only ran into that on US domestics, previously). Then we bled the brakes and everything is working great. We also replaced the parking brake cables, and another item I fixed was a broken ground wire at the connector pin inside the Left Rear side marker light - the wire broke off right at the pin, but I was able to disassmble the connector and locate a suitable connector contact from my stash of parts (I have worked in automotive Tier2's for many years...so I've acquired bits & pieces that come in handy now and again...like various connector pins/contacts).
Here's a pic of it parked on its first cruise into our local downtown - we let our daughter do the driving - she's thrilled with it!
The following 4 users liked this post by khnitz:
Welcome to the wonderful world of MINI topless motoring.
Just be aware, these are NOT drive 'em and forget 'em little critters. They do appreciate regular attention and service.
She will want to locate a wind deflector for it. One sometimes shows up on ebay. It has to be specific to the R52.
khnitz (06-28-2021)
@tcbrady , sorry that I missed replying to this earlier. The parking brake cable replacement is a little tricky, as the gas tank is in the way (if I recall correctly). All in all, it wasn't too bad (they took a couple of hours altogether). It would have gone faster had I already had my lift installed when I replaced them, but the cables were installed in June and I didn't finish my lift install until September.
khnitz (10-29-2021)
I went with a Mohawk A-7. The floor-to-ceiling clearance in my shop garage is 11'3", so the Mohawk columns fit. I also like the narrower layout it offers. I ran the hydraulic lines between the columns through the attic. My A-7 was originally in a GM Powertrain facility in Flint, MI, but passed through 2 other owners (who never figured out how to install it) before I picked it up. The biggest challange was re-wiring the controls from using the 3-phase 440V supply in the GM plant to the 2-pole, single-phase 220V here at the house. It's great to finally have a lift!
tcbrady (10-29-2021)
bradnic
02-25-2015 07:45 AM
Brownflyer1
03-06-2014 01:58 PM
