How to put mini r53 back in timing
Old 09-12-2024 | 05:32 AM
TheeSuperCooper's Avatar
TheeSuperCooper
Doing my first ever head gasket repair on my R53 mini. I marked the cam sprocket and chain but my dumb *** forgot to mark on the cam so she’s completely out of timing. I’ve been reading all the different versions of the manual and *only* the Bentley one says the bright links aren’t related to timing so now I’m a little confused on the proper way to do it. The single bright link on top lined up with the camshaft sprocket timing mark with the bright link + timing mark facing about north east, cylinder 1 is in TDC. I’m a lube tech at pretty decent mechanic shop with master mechanics but just wanted to post on here because I know BMW Mini’s are notorious for stumping even the best of mechanics. Any help is much appreciated!
Bottom crank gear timing marks lined up with 2 bright links facing down.
Top cam sprocket timing mark lined up with single bright chain.
Dimple on camshaft, I feel as if this may be related to timing but I’m not sure.
JimmyG9146
19
09-13-2024 02:53 AM
Bill Tsoukanis
11-08-2019 03:24 AM
99mini
04-10-2018 04:32 PM
Apollo_33x
08-28-2016 07:17 PM
silence2-38554
02-22-2016 07:08 AM
Quick Reply: How to put mini r53 back in timing
