MCS 2005 model vs. older MCS models
on
1 Post
:smile: silly, since the MINI seems to be holding its value (read: great resale), you may find that you are close enough in price between new and used to just go ahead and order a new one, and exactly the way you want it.
For 2005, the MCS's getrag gearing was changed, with the first gearing not being as tall. Both are FUN, though!
Clover
Clover
on
I agree with MINIclo on the price difference. I asked a question about usefulness of the 2002 – 2004 Bentley manual for use with a 2005 and Ryephile provided the following list of differences:
*different tranny ratios - makes no change in most maintenance
*different cat-back internals - makes no change in maintenance
*taillights different functionality (back up and rear fog's swapped location)
*interior oh-sh*t handle for front passenger, and driver side side visor
*center console with front cubby and under e-brake cubby
*larger rear cupholder in center console
*different supercharger part number - different rotor coating
*radio antenna now bigger/different (same as late MY04), optional part number houses Sat radio antenna also.
*door handles slightly different design in functionality only, look same
*same cat-back hangers as 2nd half of MY04
*depending on build date, clock is either in the odometer, or over head console
*speaking of overhead console, more map lights for front passengers
*bigger door card armrests - no change in maintenance
*different seat bases.
As you can see this list focuses on mechanical differences and not on options like body colored dash panels. In addition to the above, they made a limited slip differential an option in ’05.
"The 2005 MINI Revealed"
http://motoringfile.com/2004/02/01/t..._mini_revealed
"Merry Christmas, here is the 2005 MINI"
http://motoringfile.com/2003/12/23/M...resThe2005MINI
"Autoweek on 2005 MINI Changes"
http://motoringfile.com/2004/04/29/a...5_mini_changes
"Q&A with Eaton on the 2005 MCS Supercharger"
http://motoringfile.com/2004/05/08/q...s_supercharger
"2005 MCS Motoringfile Review"
http://motoringfile.com/2004/08/31/2...ingfile_review
"MINIUSA Officially Announces 2005 MINI changes"
http://motoringfile.com/2004/05/14/m...s_2005_changes
"2005 MINI Advanced Airbags"
http://motoringfile.com/2005/01/29/advanced_airbags
There are a million more articles at: www.motoringfile.com
Do a search using key words: "2005 MINI". That should give you 280 article matches.
Plenty material to read. Should give you a good idea about the 2005 vs 2002-2004 changes.
More or less maintence on supercharger?
on
Nice detail info, Thanks NealW
A couple more...
Additional changes:
The 3-spoke steering wheel vs 2 spoke, and now the MFSW has 2 phone buttons.
Car will be pre-wired for rear foglight, alarm, and homelink rearview--(possibly mic pre-wired for bluetooth)?
Low washer fluid light on the wiper stalk.
Originally Posted by ariercetinberk
163 hp vs. 170
They also changed the chrome sorround for the front grill from ribbed to smooth, and redesigned the headlights, available red/yellow/blue colored dash on MCS.
As well as some option tweaks. Standard cup-holder, availability of chrono-pack, sweet arm-rest, an extra side sun-visor etc...
Originally Posted by jds
MCS owners......in relation to pre-'05 MCSs......have the early "stumble' and "yo-yo" issues been adequately resolved??? I have heard of lingering symptoms in some cases, although these phenomena seem non-existent in the '05s. Thoughts?
Part of it's me, for sure (I'll apparently *never* unlearn my "technique" gained from learning to drive stick on an underpowered Cherokee...), but most of the blame lies within the engine, I think.
While I'm nitpicking, I also think the torque reduction by the DSC is way too much. Chirping the tires while getting a little overzealous with the throttle trying to zip across a couple lanes of traffic often leaves me praying to a higher power for more power. I read that the MTH ECU remapping can adjust how much the torque gets cut...
My '05 MCS is smoooooth as silk and accelerates strongly from the get go with none of the symptoms you describe. Either something is wrong with your car or your driving technique.
Originally Posted by blalor
I've just got generally poor throttle response on my '05 MCS. It is very abrupt; backing off a little on the throttle while accelerating produces a very noticable cut from the engine, instead of a smooth transition. I'm beginning to think it's just part of the character of the MINI, but one I'd rather go without. It's magnified by the air conditioning. I also wish the throttle was more responsive from idle; I usually either bog the engine or spin the wheels pulling away from a stop light.
polotska
08-23-2015 09:10 AM
