Caring for the Rag Top
Try the 303 stuff
www.303products.com/main.php?infopage=kits
My MINI is relatively new -- I've only used these products once. They came highly recommended and seem to work well.
I never noticed any factory protectant - no signs of water beading up when I first washed her. I used the 303 top cleaner per their directions and then after the top was dry I applied their protectant.
For the next several months you should be able to just rinse off the top w/o using any soap - at least that's worked for me.
#1: Search the detailing forum... I know I've seen this before on NAM and there was a bunch of good information
#2: 303 makes some very good products. If your car is new within the past few months, go straight to the protectant. If not, use the fabric cleaner then the protectant.
#3: If you keep the protectant up to date (follow the directions for how often to re-apply) then you should be able to wash the roof fabric with car wash water and a mit during your wash. I'd recommend a wool mit or microfiber... Chenile or cotton will probably leave your top 'linty'.
#4: I would think that it would be good to store the car with the top up... just to reduce wrinkling and to reduce dust in the interior. I don't think that the occasional night with the top down would cause any worry, though.
bADbOYbECK
41
10-16-2015 12:39 PM
