Help...Frozen Gas Cap
I've used quartz element space heaters to warm up sub freezing motorcycle engines. A strong utility light will work too.
But having just picked up my '06 MCS in the middle of a PA Jan., I wanna know how to get the road salt off the car without dousing it with a car wash. That is precisely what I want to avoid....frozen doors, windows, gas caps, wipers....etc. I didn't care about the salt on my old car. It usually waited till spring. But a new car coated with salt? It makes me want to jump out of my skin. A caravan to South Beach might be in order.
I didnt mean to imply opening the frozen outer door(which is already frozen shut),take off the gas cap and point the heat gun at the gas fumes .All joking aside,warm air from hair dryer does the job without using water which will refreeze.If you wash by hand I blow dry car after with leaf blower it does one hell of a job of removing water in a hurry,with out any fancy handwork.That could be another thread though.
If you can open the rear hatch, try this:
Remove the driver side storage compartment lid (the one in the boot). Take a flashlight and look into the compartment. You should see a white plastic handle with a gasoline pump symbol on it, it's the emergency release for the fuel filler cap. Maybe it is too frozen for this to work but it is probably worth a try. Pull back on the handle with your right hand and open the filler cap with your left. Isn't MINI brilliant? Too bad the forgot to put the rear hatch emergency release cable on most of the "02 cars!
Good Luck
Good Luck
riff42
09-22-2015 03:07 PM
