run flats vs. NOT run flats
#51
Originally Posted by Dr Obnxs
the Bridgstone RE050A is NOT a runflat tire. The Bridgestone RE050A RFT is. As I look over the tire rack website, there is no way to really sort out the difference between the rating and exactly what tire was run.
There are not enuff reviews to place that tire in the actual survey, just mostly good comments. Since that tire has only been out since Feb, we need to so out it plays out in a year.
As to eating a set of tire in 7 months
#52
Originally Posted by silverdragon
my 02 S curretnly has perelli run flats...the have started leaking ...one more then the others..i have heard this happens. Opinions on replacement tires...not necessarily run flats...heard there are better options for us, weight and ride-wise....
anyone..?? Opinions..?? places to buy in Southern New England?
#53
Matt
#54
I will tell you this, the faster the car/truck, the better they handle, the MORE RUBBER you'll go through.
I do not know if the Mini is the first High Performance car for most but I have had my share, Mustang GT, Camaro IROC-Z, Cougar XR-7, even the Ford Focus ZX-3 and 2500HD(lots of HP) we have right now. Tires DO NOT LAST we tend to take turns fast and we are quick off the line. The Focus and truck usually goes through a set of tires a year and my truck has 265 E-rated tires. All three of the older cars had Goodyear Gator backs and they did not last long at all.
I am trying to say that these are great handling and fast little cars. Your probably not aware that you are taking the turns a bit faster than the Crown Vic. And this has nothing to do with RFs or non RFs.
But if you have been behind the wheel of cars like these before than the lack of tire life is nothing new.
This is a fact of life.
Like someone said, this is a debate that has been beating with a wet noddle over and over again. And there will be no winners.
#55
on
1 Post
Originally Posted by eVal
My gosh, I just put the wheels with runflats on again* and was completely appalled by how awful it was - it felt like I was running on square tires made of stone - bad ride, bad grip, bad performance, blech. I had forgotten just how cruddy they were compared to the better rubber and light wheels I had on. The KDWs may be horridly noisy but they are certainly more fun then the runflats!
*I had the S-lites before with RFs and now have the smaller X-lites with RFs - I thought they would be better then the larger ones sinced they are lighter and, I think, have more sidewall but they certainly do not feel better :(
#58
Actually, the thing I've noticed with our 3 week old Mini is a lot of road noise.
For the regular person it's very apparent but since we own a Mustang GT and a Jeep and a heavy pickup truck, we are used to it.
Mini actually rides the smoothest out of all our cars even over bumps with the runflats. It's a firm ride but way different than our Mustang.
Kimolaoha
12-05-2020 09:32 PM
