European license plate
If you google "euro plates" you will find lots of sights. Here's one for a quick link, good luck.
http://www.europeanplates.com/
I order mine from http://www.myshowplates.co.uk/ . It took a couple of e-mails but they have a great product.
on
When you order your European plate, you will also need to order the frame. The plate has no holes for screws to mount the plate. The holes are in the back of the frame, then once the frame is in place, the plate goes into the frame. There are numerous variations and one of the mounting hole variations lines up with US plates.
Originally Posted by Jayne
I don't have my MINI yet and I am a novice to the European plates. How do these attach compared to US plates? Do I need the dealer to do something different to use one of these?
If you don't want to drill holes (which I did not want to do) I used two nylon zip ties and fastened the bracket to the bumber through some slots in the lower grill. Worked like a charm and has stayed on there for over a year without a problem!
I ended up getting a bracket from the MINI of Munchen dealership in Germany when I was over there last year and brought it back.
The ones the eurpoeans seem to use are made by Wurth so you may want to do a search for them.
chris
chris
chris
chris
Interior/Exterior Chrome strip above license plate, who makes black ?
got_mini?
10-07-2015 02:12 PM
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:28 PM
10-01-2015 12:13 PM
