coastie
Well, the manual trans S loves to run to redline, 6750-6950 depending on the model with No problem. Same engine, same valves, so I think its telling you More, More, not enough, enough! Its a strong engine, made to run at high revs. Some of the folks on this board have 02's and 03's and regularly run them to redline and their engines are fine. Now that's running it to the line and shifting right away, not sustained revs but I'll let the rest weigh in. The caveat is: I don't know what sounds your engine is actually making. Ugly, unharmonious sounds may be signs of trouble. If you know someone with an S, it may be prudent to let them listen to it but with 2000 miles, its most likely fine.
Thanks for the info miniclo. Brought the engine up to 5000 rpm's with no problem. I'll try the sport mode today. I thought i was going to blow the engine one day when i accidently pushed the paddle down to first gear when i was doing about 40mph. It really raced. I did'nt think it would go into any gear shouldnt be in. Jim
^^^ My friend's A3 with the shift paddle won't go into a gear that will mechanically damage the box, and I imagine that your MINI has the same safety feature. When you accidentally down shifted to 1st, did you happen to catch a glimpse of what the tach went up to (amidst your heart failure)?
If it didn't redline, I'd be impressed, but in the end it probably 1) didn't redline or 2) you weren't exactly at 40mph at the time. In anycase, glad your MINI is ok!
