R60 Optional rear bench seat
#127
#128
haha, nice. BUT... a few errors.
1. The lack of the center rail is a huge positive, not a negative.
2. The complaining friends thing doesn't make sense. You are not forced to sit 3 back there just because you have the bench.
3. "very conventional" should be changed to "Practical" making that one an even draw.
#129
#130
4.5? lol ... They do. They move forward and back and 40/60 split rules apply.
#131
That forward/back/recline(?) thing is the one thing I think is groovy about the buckets.
#132
#133
Ya, which is kinda my point and why it's ridiculous that a thread that was started as a simple question to the availability of a bench has turned into an argument for and against the two perfectly valid options. What works for one, doesn't work for another so options are a good thing. If you own the buckets, you don't need to validate. When you do, it reeks of feelings of inadequacy or jealousy. No one is arguing over or hijacking threads over any of the other options like Nav or Mini Connected for example. I fail to see why a bench seat option has pushed so many buttons, other than what I already said. I see this thread come to the top and I open it in hopes of seeing an update to the question at hand, and instead it's more drivel. Your chart was amusing. It was your opinion which is fine. I gave mine. To reply with "to each her/his own" is and so obvious that it doesn't really need to be said. Does it?
#134
I have no intention of causing a debate. My "amusing chart" - thanks! - should not be taken so seriously. It's only my opinion... to each her/his own!
Last edited by silvernuke; 04-20-2011 at 04:10 PM. Reason: replace 'correct' with 'valid'
#135
They do split and it seems they are worth the wait.
Car and Driver:
"Rear seats will slide fore and aft —the bench in a 60/40 split —and fold individually (or in 40/20/40 increments with the bench). "
http://www.caranddriver.com/news/car...hotos_and_info
BMWblog:
http://www.bmwblog.com/2010/09/07/ph...-its-uk-debut/
"The multi-function rear seats are arranged with a 60:40 split base for the three rear seat passengers and both rear seat squabs are also individually adjustable, sliding back or forth by 130mm to make the best use of space. The backrests, by contrast, are arranged in a 40:20:40 split that provides absolute flexibility with all three seatbacks capable of folding flat in any combination."
Car and Driver:
BMWblog:
Looking at these images, I think I see 2 LATCH icons at the base of the middle seat but I dont see the rear tether for a baby seat behind the seatback. I can see them on the 2 outer rear seats but nothing in the middle. Does anyone know if you can even mount a baby seat in the middle using the LATCH harness?
#136
Not sure, doesn't look like it, wouldn't be a problem with a rear facing infant car seat, as the don't use the rear, just the seat mounts. Once they switch to the forward facing that uses the rear latch point, I would never keep it in the middle any way. My other concern if I was mounting the baby/child seat in the middle is your not actually going to be able to fit another passenger or seat on either side.
#139
#140
Really? Funny then that it worked well for a shortish trip - in preference to leaving one behind. (None of the three would want to do a trans-continental tour like that but needs must sometimes.)
#142
What you show in your pic is normal.
The car seat in the center though... i can see that being a problem for additional passengers... but again, no different than any other car.
#143
Coming from a MKIV Jetta, we can barely fit 2 smurfs on each side of our middle baby seat anyways so Im not too concerned. We dont haul passengers besides our little one and her gear. If I was going to mount the car seat on the side, id might as well get the rear buckets.
#144
As for those with dogs, not sure if most saw pooch style released a dog mat for the car: http://www.poochstyle.com/store/pc/v...dproduct=27137
interesting part is it features an optional cushion for the rail, wonder if this could be used on its own?
http://www.poochstyle.com/photo_gall....asp?PID=27137
#145
#146
Thats what it looks like, although not a good pick (might just fill the area with the seats down). Still I can see similar products coming out with time, nice option cause you get the best of both worlds.
#147
While waiting for an "Official" product to "bridge the gap" between the rear bucket seats, I may purchase a massage table bolster and wedge it right into the crack!
http://www.massagewarehouse.com/sear...Sort=2&F_All=Y
#149
Well, i still don't see any real advantage to the buckets especially since I won't be sitting back there, but it might do if someone didn't want to wait for the bench.
#150
Well to each their own but to me they look much, much, better (both the seats and the light rail) and are more comfortable for the rear passengers as they have better bolsters. Plus you get rear cup holders (and other attachments if you want) with the rail, something you'd lose with the bench.
