R60 Pulling a trailer with a Countryman?
#51
on
I just had a Sport Link II installed on my R56 and I saw the CM prototype at the MINI-FINI shop. It was rated by an independent test compay as a Class II hitch. Like all of thir products it is very well built. While MDM makes a good product, the best is the MINI FINI products. Pricey? A little. But highly worth the extra cost. I had first class service from Russell. I got the cargo carrier and it too is well built. This is the only wat to go.
By the way. I do not have any affiliation with them other than a very happy customer...
EDT: Actually I entered a typo. It is rated as a CLASS III, not Class II. It is very well engineered
#52
#55
c-link for Countryman?
#56
#57
#58
Trailer towing capacity are limited by the car, not the hitch. I have not yet seen the CM's rated towing capacity...but with 180 hp and small-ish size, I'd not expect more than Class II capacity (less than 3500 LBS gross trailer weight). A class III hitch is rated to 5000 LBS...way too much for the car I'd bet.
It may be the minifini hitch is engineered to take a class III limit, but that car limits that to class II or maybe even a Class I.
Mike.
#59
https://www.northamericanmotoring.co...t-hitched.html
#60
#61
Had a nice long talk with Russell at MiniFini and ordered their Countryman hitch. Confirmed that it is a 1 1/4 inch receiver hitch that is accessible below the license plate through the vent hole area. Installation will require removing the bumper cover, bolting on in existing screw location and cutting a hole in the vent area the size of the 1 1/4 opening. He was in the process of writing up instructions to install and mentioned that it isn't hard other than removing some finicky clips that are new to the Countryman. They also sell a wiring harness for a light solution that I ordered that includes fuses and relays so that the computer is happy with tapping into the rear tail light harness.
Russell took a lot of time on the phone with me to chat about his business, took an interest in me as a customer and just seems to be an all around great guy with a solid business. I would rather pay a premium for a product from a solid and honest person like him any day than to a nameless, faceless website product that has questionable quality. There is no doubt that Russell will make sure we are happy with this product.
#62
on
A big plus to everything said. Russell and his wife are also a MINI enthusiast[they have two plus a really cool looking Classic Mini] that I saw at his shop in Columbus] and it shows in his work. One other thing to note is that Russell said that he will be able to attach a Sport Link similar to the Sport Link II design on a Countryman so if you have older attachements for the Sport Link or are a two MINI family [like my wife and I: R56 and R60] the attachements can be used for either car.
I was a
I was a
#63
My concern is that to install the pin that holds the ball mount you have to reach way up behind the bumper. If you don't mind leaving the ball mount on all the time this may not be an issue for you. I however, would prefer only to have the ball mount when I tow and have the flexibility to easily switch to a 1-1/4 receiver bike rack. If this assumption is correct then I think I may hold out for the "sport-link" type solution.
#65
Annette
#66
on
Another reason I opted to g with the MINI Fini solution. All I have is two Stainless Steel ports comig through the rear "grill". It actually looks pretty cool. You can also opt to have it cut to accomodate to rubber caps that will fit and make the ports hidden for the most part.
#67
Here's a pic of my '06 with the tow attachment through the fog light.
And a pic with the fog light back in place.
Annette
#68
on
Well looks weren't my only reason. There is also strength and build quality. He used a high tensile, lightweight steel in the fabrication. It is very strong. The Sport Link II with hitch is rated as a Class II hitch which means it has the strength to suspend a MINI and five 200 pound men. The Countryman hitch is rated as a Class III hitch which is a 5000 capacity. You do not want to tow that much with it. The fit and finish is impeccable. I only bought it for the cargo carrier and will probably never tow anything. WE may use the the bike rack option but not yet.
The other consideration is the ease of putting on the accessories. Simple process really. Hold the attachment in the 90 degree position to the car and insert the right attachment bar into the port. lower it to horizontal and slide the left bar into the port. twist the handle around and is secured in place. Engage the lock and yo are done. Maybe 30 seconds tops. No crawling around on the ground or burning you dingers fumbling around for the pin. check Russell's site.
I think the MDM hitch is adequet but not as good of a solution as the MINI Fini. Keep us posted as to what you decided. I can psot some pictures of mine in the near future..
#69
extra holes
I was hoping mini-fini were going to be able to utilize the existing hole cuts outs in bumper (which I think are for towing eyes)
Any idea why not - I heard something about a peculiar thread type
In any case I have asked for some pictures of the MINI-Fini but if you have them already OregonMountainMan please post em up :p)
#70
While trying to find out which vendors were scheduled to be at AMVIV this year (hoping MINI FINI was) I came across:
www.caboosetrailers.com
Check out their system specifically for the Countryman which utilizes existing holes. LOTS of photos. Love the trailer with sport stripes!
I know nothing about this system...just stumbled upon it.
#71
So I'm heading over to pick up my MINI from getting the driving lights installed and notice this place where a Saturn dealership used to be.
Kind of interesting, wonder when they'll be doing a MINI.
http://www.execuhitch.com/index.aspx
Annette
Annette
#73
#74
Caboose Trailers has the dubious distinction of being one of the first (perhaps THE first?) commercially available Countryman hitch receivers on the market and it shows. I like that the receiver is completely external to the vehicle, making for easier access for mounting and inserting hitch pins and locks, but their design looks rather ugly and amateurish -- I'd hesitate to leave it on when I'm not actually using the hitch.
#75
http://www.minidomore.com/mini_coope...iler_hitch.php
http://www.etrailer.com/faq-hitchclasses.aspx
