R60 Connected/Nav: Audio,Video,Telephony
Old 03-19-2011, 10:38 PM
punkrockdoc's Avatar
punkrockdoc
punkrockdoc is offline
Using the "plugin" option under Mini connect, I get all of the artwork with no delay, even artwork that I did not get when accessing the iPhone vie the External Devices option. You do not need to have the mini connected app running to get the plugin option - just hook up an iPhone or iPod.
  #227
Old 03-20-2011, 05:16 AM
Cosmic Blue Conspiracy's Avatar
Cosmic Blue Conspiracy is offline
There is a script for iTunes (I don't remember the name now but google it) that embeds the cover art in the song file. If these are MP3s you've burned from CDs, that cover art just gets linked. Try embedding the art using that script in the songs you are having trouble with and see if that helps. I had to use this to get cover art to show on my Blackberry when I had it for non iTunes Music Store purchases.
  #228
Old 03-20-2011, 09:39 AM
Guards Red Car's Avatar
Guards Red Car
Guards Red Car is offline
Blackberry Curve Bluetooth Pairing? Cradle adapter?
For Bluetooth pairing,
When I search http://www.mini.com/connectivity/ Compatibility check, I only see Blackberry Tour and Storm listed
I have a Blackberry Curve 8530 - Will this pair?
I do not see a cradle adapter available for the Curve, will Mini offer this in the future?
  #229
Old 03-23-2011, 08:42 PM
spaner's Avatar
spaner
spaner is offline
yep I get the $hitty resolution also
It seems like they really do need to cleanup the connected/radio app - Lots of good features but actually to many choices and redundancy - It feels like two groups developed the applications and they failed to have a system guy pull it all together - Oh well I got a feedback form in the mail so will see if I can at least get comments to MINI on this
  #230
Old 03-24-2011, 04:05 AM
RS11's Avatar
RS11
RS11 is offline
I can't get to the music on my iPhone through the plugin option under the Mini Connected menu. All I get on that menu is a message like "plugin is ready". I can get to music via the external deceives option. How do you get to music via the plugin option?
  #231
Old 03-24-2011, 05:05 AM
You have to make sure Mini Connected is the active app on your iPhone.
  #232
Old 03-24-2011, 05:15 AM
Ted U's Avatar
Ted U
Ted U is offline
Does the plug in option only work with the Mini/BMW USB/video Y cable? My iPhone 4 does not charge with that cable so I have been using the white Apple USB cable for my connection.
Thanks.
TU
  #233
Old 03-24-2011, 06:04 AM
Flyer53's Avatar
Flyer53
Flyer53 is offline
Yes..Iv'e been using the same cord as well...more places to keep the I phone,
but you do loose some of the functions in the Mini Connected area. The Y connector that came with the vehicle should be charging as well for you.
  #234
Old 03-24-2011, 06:34 AM
punkrockdoc
@RS11 - Try clicking the **** down when it says "Plugin is Ready".
As for the resolution, I think it might be a setting in the phone that we probably can't access/change. The mini connected screen can obviously handle a pretty high resolution. I'm just surprised that the iPhone doesn't output at higher resolution, since it can output highdef video to a TV through an optional HDMI attachment.
  #235
Old 03-24-2011, 06:42 AM
Ted U's Avatar
Ted U
Ted U is offline
My iPhone just doesn't connect with the supplied Y connector. My iTouch will connnect so it's not the cable. Any suggestions? The Mini Connected app "test" function reads unable to establish connection with device.
  #236
Old 03-24-2011, 10:16 AM
punkrockdoc
Is your iPhone jailbroken? that has caused some problems for other users.
Other than that, I'm not sure. Maybe make sure that you have the latest version of the software. I don't think that will make a difference, though, because I was running it first version of OS4 and the first version of Connected (without facebook) for the first week that I had the car.
  #237
Old 03-24-2011, 11:25 AM
Ted U's Avatar
Ted U
Ted U is offline
Nope. Not a jailbroken phone. I have the latest version of Connected as well as OS4.3. I'm not sure either...will mess around again with it tonight.
  #238
Old 03-24-2011, 01:21 PM
Flyer53's Avatar
Flyer53
Flyer53 is offline
Stopped over to see my MA at the dealership..I'm refinishing (Powder Coating) his aluminum wheels for a BMW...so I stopped by the parts department..and the cradle for the IPhone 4 is available !!..I ordered it..$165. and I'll see it Monday..no later than Tuesday So check with MA's or even better parts department because...there available.
  #239
Old 03-24-2011, 01:28 PM
MaybeMCSC's Avatar
MaybeMCSC
MaybeMCSC is offline
To use the cradle - will you run the same cable that you use today into the armrest? Or is the armrest prewired in some fashion, such that when you put the cradle in it and then the phone in the cradle, all is connected?
Thanks in advance!
  #240
Old 03-24-2011, 01:32 PM
Flyer53's Avatar
Flyer53
Flyer53 is offline
It's all prewired...not sure what that option was..6NE & 6NM I believe.
  #241
Old 03-24-2011, 02:10 PM
Flyer53's Avatar
Flyer53
Flyer53 is offline
GeoffreyM...Did you ever get your I phone cradle ? Was it indeed Part-number: 84212199392. Just Curious...ordered one as well and parts is saying the only one available is the 1st one you have listed.. Thanks
  #242
Old 03-24-2011, 02:28 PM
rsbell's Avatar
rsbell
rsbell is offline
@Flyer: in case my MA gives me the run around on the cradle, which dealership did you order it from so I can give them a call?
Thanks!
  #243
Old 03-24-2011, 02:51 PM
Flyer53's Avatar
Flyer53
Flyer53 is offline
New Country Mini..Hartford, Ct 860-522-6134 There only showing 1 part #.
I have seen a few posts on here describing 3 different part #'s..But for the I Phone 4..there is only one. I should have it Monday ..no later than Tuesday and I'll post which it is...and hopefully all it can do
  #244
Old 03-24-2011, 03:23 PM
cpomeray's Avatar
cpomeray
cpomeray is offline
I tried ordering the cradle using one of the part numbers previously posted and got a call from my mini parts department today telling me that it was the wrong part number and that they are changing the order to the correct one for $165. I was told it should be in by end of next week.
  #245
Old 03-24-2011, 05:08 PM
days-like-this's Avatar
days-like-this
days-like-this is offline
Hmm. Is this the iphone4 cradle that Ryanzak already reported having that DIDN'T work? Maybe cross reference with him/her to see.
  #246
Old 03-24-2011, 06:50 PM
Flyer53's Avatar
Flyer53
Flyer53 is offline
Well the $165. Price is what I was charged...so must be the same part.
It sure sounded from the parts guys that the different part #'s were more for the type of phone and not what it does. They actually ordered the part using my vin # which would indicate what type of features I ordered in regards to the connectivity. They said there were 1500 allocated for the US and 50 where in the local depot...wherever that is. Either way I should have it Monday.
  #247
Old 03-24-2011, 06:58 PM
days-like-this
Fantastic that you got your hands on one, even to just see if it works. So, thanks for posting the info. Fingers crossed that it IS the right one. Can't wait for you to get it on Monday
  #248
Old 04-11-2011, 07:19 AM
Ryanzak's Avatar
Ryanzak
Ryanzak is offline
Days like this.... Did the cradle end up working for connected? If so can you confirm the part number? You're in my hometown! Cool, Mini of Murray treating you right?
  #249
Old 04-11-2011, 07:44 AM
Flyer53's Avatar
Flyer53
Flyer53 is offline
Copied this from a previous post:Ok.... Just picked up the I phone 4 cradle that I ordered off the Mini Accessories site from the dealership. Unlike the three BMW #'s that have been listed here. This Mini part # is 84-10-9-164-123 ... When ordered from the site stated we needed options 6NF & 6NE. Box even states music after the number. So I was thinking this was equal to the BMW # ending 391. I recently ordered and then returned the basic #389. Well this was no better than the first one I returned. It charges but would not even play the Bluetooth or I should say it did and the screen showed the songs.. No artwork but also nooooo sound, no music at all. Pop it out of the cradle and all was fine. Actually this cradle did not look as sturdy and the phone seemed to be a bit tight. Not as nice of a fit with the 389. So that's it for me....I'll return this one and just have to wait for the right one...whenever and which ever one that is. Looking forward to any others that thought they might of stumbled onto the correct one!
  #250
Old 04-11-2011, 01:54 PM
GeoffreyM's Avatar
GeoffreyM
GeoffreyM is offline
Sorry Flyer. Didn't see this until today. No, I never got it, I'm in the same boat as everyone else. It really is pathetic that they can't get this together.
Quick Reply: R60 Connected/Nav: Audio,Video,Telephony
