R60 2011 Mini Countryman Power Mirrors
I was just wondering if anyone else has had problems with power folding mirrors on their Mini Countryman? I have a 2011 Mini Countryman ALL4 S special ordered with EVERYTHING but GPS. And I mean everything! In the one year that I have now owned this Mini (Mar 2011 - Mar 2012), I have had to take it to the dealership 6-times for failing power folding mirrors. They either unfold or fold to 45-degrees and stop vs. the full 90-degrees. So far my dealership has replaced both mirror motors, the mirror motor control module, and performed 3-different software updates on the ECU along the way. It's really been quite a hassle. When I ask am I the only one out there with this issue, they tell me they've never seen another Mini Countryman with this problem? So, has anyone else out there had this problem with their 2011 Mini Countryman? ...or am I truly the only one? Thanks for any feedback.
I use mine all the time and have not had an issue. At this point I'd be suggesting to service that something else is causing the problem ... like maybe high resistance in the mirror assembly itself causing the motor to fail or the fuse to blow. Most people do not know how to properly troubleshoot by not finding the root cause of the problem. Maybe have them talk to Mini engineering or support.
Thanks sirbikes
It hasn't been that long since the last service, and the mirrors have only been used a few times since, however they have worked in those few times. I'll keep everyone posted. I was mainly just wondering if I was indeed the only one with the problem. So far, looks like 'Zaftig' has it also
Thanks Bmtespar
My issue started out with both mirrors randomly stopping when unfolding at roughly 45-degrees. The issue then progressed to both mirrors randomly stopping when either folding or unfolding at 45-degrees. And from there, they progressed to both mirrors intermittently (either driver or passenger by itself), randomly stopping at 45-degrees while either folding or unfolding.
As a mechanical engineer myself, I don't understand what is so hard to fix here. Why don't they simply have an open and closed switch. When the mirrors are activated and rotate the full 90-degrees, which would trigger either switch, then have that switch relay to the ECU to cut power to the mirror motors, as they have either been fully opened, or fully closed. It really should be that simple! My Mini dealer tried to tell me that power mirror failures have no hard code, and that failures are not logged by the ECU. Yet in one of the 6-repair attempts thus far, I was advised that my mirrors had triggered a hard code. When I confronted my Mini dealer about the contradiction, they developed a bad sense of the stutters in trying to explain what they couldn't. It's just been extremely poor service so far for my very first Mini
Please don't flame me for this, but why do people need power folding mirrors on the Mini? I have them on mine and the difference between folded and unfolded is only an inch or so. I never park my baby close enough to anything where I would be worried about hitting the mirror. I understand the need on an Escalade or Explorer but I only have it on my Mini because it came with the package.
Just curious...
Just curious...
Hey Verc,
Just curious...
Just curious...
My answer may be wrong, but I'm willing to bet a word that rhymes with "schmoney" somehow factors in!
Back on topic - I've got the power mirrors too (came with package) and have also encountered the freeze up 2 times, but both times I encountered them, there was ice build up around the base housing and that's what I figured stopped the motor. Have the other issues occurred when some obstruction wasn't a factor?
Hopefully the service guys were at least entertaining when they started tap dancing! Let us know what comes of this & good luck!
Thanks Rktcyntst,
As an aerospace engineer that's in an engineering management position accountable for cost & schedule, you get 3 chances to address why the solution requiring additional hardware per vehicle may have won out in the original design prior to getting this customer feedback (I'm pretty sure you already know the answer!)
Thanks chrunck,
My issue is, for the amount of money I paid for this special ordered Countryman, I shouldn't have to contend with such annoyances.
You're absolutely right. For the price of these things, this stuff should 'just work'.
Well, since you brought it up . . . no, I won't even say it.
Zaftig spends time on a narrow street and always gets his mirrors folded - for reference, my SO forgot to fold the mirrors on my BMW and it cost about $500 to replace one that got hit in the night. Zaftig also gets them folded at the Metro lot and in most parking lots. People around here have about -100% respect for other's property. You do what you can not to make it easy for them.
on
I use mine every time i park.I bought the car used and i own it 4 months now.Many times the mirrors stop at 45 degrees but then i m using again the button(for the mirrors)to the opposite side and everything is good.I m not going to the dealership cause i dont want to spend money for this small inconvenience.
07-16-2020 12:54 PM
dyeLucky
08-07-2015 07:10 AM
