R60 Need advice with exhaust tips
Any muffler shop should have a selection of tips for you to choose from. That is how I picked mine.
I also sent the tips to Sanderson Headers in South San Francisco to have them ceramic coated flat black. Cost about $90 but the coating will outlast the exhaust (i.e. never rust). If you go with powder coating it will start to flake off due to the heat. I'm sure if you look on the web you can find some place close to you.
Also they can not be very long as there is a bend in the pipe at about 8" back.
Good luck!
Good luck!
I didn't do the welding, so I don't know for sure. I originally had the tips on my stock exhaust and then moved over to the NM exhaust. The only complaint I got from the muffler shop was that they would have to weld in an intermediate piece to transition from the stock 2.5 in pipe to the larger tip and that the welds might look a little rough. I said who cares, it's under the car.
Ok , Thanks, DiMisa makes tips specific to the R60 , as they made them for a customer , I'll see what they say to my request
Cheers
Cheers
08-12-2015 01:24 PM
08-10-2015 02:03 PM
08-10-2015 01:59 PM
