R60 R60 sway bar setting on a JCW
Hi, I'm just fixing to add a 22mm (nm Engineering) rear swaybar and was wondering what everyone is setting them to. The hole at the end or the one closest to the bar (front of car). I know the last hole (at the end) is the soft and the inside hole in the harder setting.
I was told to use the harder setting since I have the JCW and it would give me the maximum performance from the suspension.
Any thoughts???
Thanks.
Any thoughts???
Thanks.
Cool, the nm one I have only has 2 setting, no middle hole. NM suggested the hole closest to the bar (front of the car). A few others suggested this too... I heard the hole at the end of the bar is still similar to the OEM setting, not sure how accurate this info is but I guess it's easy to swap the holes.
What about Target to Home Depot....lol.... Yeah well I have 2 jacks so I may play with the 2 different settings and see what's best for me... I assume the alignment will not be affected for a hole relocation job... I'm getting an all 4 alignment done after the bar install.
07-16-2020 12:54 PM
minipopkart
08-13-2015 05:22 AM
ClayTaylorNC
08-10-2015 09:19 PM
