R60 Water Pump Failure ?
Vendor
You only need to change the thermostat and temp sensor if they are actually failed as they are on the other side of the engine so the labor doesn't overlap.
We keep the new all aluminum pumps in stock
http://www.waymotorworks.com/water-p...8-r59-r60.html
Vendor
Replace the water pump if it's leaking. We have them here. Genuine or OEM supplier is recommended. Be sure to use MINI coolant HERE 50/50 mixed with distilled water.
888.280.7799 | 6am - 5pm PST
What year do you have ? Yes I would do the Waterpump and the thermo at the same time.
All the Genuine MINI ones Water pumps are all metal on the outside as well as the aftermarket ones we carry the Febi one has a metal impeller also. 11517648827
https://www.northamericanmotoring.co...8-no-heat.html
daonlyillwiz
R60/R61 Stock Problems/Issues
44
07-18-2023 06:06 AM
[My_Mini]
01-11-2016 12:31 PM
Robert Pritchard
R55 :: Clubman Talk (2008+)
01-06-2016 08:20 AM
