R60 2012 Mini Countryman S Rough idle
Good Evening,
I am new to this forum as well as a new Mini Countryman owner.
I recently purchased a 2012 Mini Cooper Countryman S w/61,225 miles. When I start it, it starts fine but within 1 min., the RPM's drop, and the car starts to idle irattic for about 1.5-2 minutes then smooths out and is fine. Last week, check engine light came on so I took it back to the dealer yet again. In short, they found that the fuel pump needed to be replaced as well as needing new plugs. This morning, I started it up and the same symptoms are there. In fact, I started it up this evening and still had the same fires right up then within a minute, RPM drop, rough irattic idle.
Has anyone else on here had this issue? I forgot to ad, I did put some 44k in the tank about a week ago hoping that would help with carbon in the injectors.
Any help on this matter would greatly be appreciated.
Good Evening,
So the dealer replaced the high pressure fuel pump and it still do that??? Ignition coils? Is your Mini still under warranty and they replaced under warranty??
Good Evening,
MidwayMountaineer
06-27-2022 07:39 AM
