R60 Oring on the back of the water pump
The o-ring(near the pump) does not leak most of the time the end pipe can crack and get a hairline crack in it. At the clip part to the waterpump i have seen that leak. Most of the time the clip is missing of after a water pump replacement the back end of the theromstat was not seated all the way in the water pipe.
DIY here: https://www.northamericanmotoring.co...hermostat.html
and Here: https://www.northamericanmotoring.co...stic-pipe.html
Yep, you can do that since the thermostat housing is good. That way when you take it apart you will have new gaskets and not older gaskets that have been compressed.
89325iturbo1
02-17-2019 04:06 PM
theimage
02-05-2018 07:13 AM
Little Bean
R55 :: Clubman Talk (2008+)
12-26-2012 03:23 AM
